Can't install Daz 3D Mac Mavericks
sjuricksjurick Posts: 0
I've downloaded the Download Manager for Mac. Started install but receiving several "Error creating directory" messages... Not sure what to do or if there is something I need to change in the way of permissions maybe?
I've included two of the messages, but I get a bunch of them.
Any help appreciated.
  • TotteTotte Posts: 15,173
    Which user where you running from? A user that can sudo (can become admin)?
  • sjuricksjurick Posts: 0
    My login has admin rights yes.
    Are the permission on /Applications correct?
    Have you tried repair permissions with DiskUtilities?
    I ran repair permissions on the App disk. Hundreds of changes made. Daz 3D still gives error messages.
    Did an Info on /Applications directory:
    Steve(me) : Read & Write
    system : Read & Write
    admin : Read & Write
    everyone : Read only
    Is there something else I need to change?
    Should work, I don't have any 10.9 machines without DIM installed so I can't test, but did it create any directory named DAZ 3D in /Applications, and what is the privs on that, might be an installer bug. Which version of DIM btw?
    Installer is 1.1.0.7
    It did create a /Applications/DAZ 3D directory. Attached is the screenshot of the perms. Looks like it's not inheriting? Do I need to Read & Write the entire DAZ 3D directory perhaps?
    514 x 858 - 105K
    Changed admin to Read & Write on the DAZ 3D directory and installer is now working ;)
    edited April 2014
    OK,
    This is a bug in the installer-script (Not DIM itself). It only happens on first time installs, not on upgrades as then the DAZ 3D directory is already setup OK, (hence no one has seen it I guess).
    I reported it the bug btw.
    Just set yourself as owner and remove system as owner. You might see the same problem on the ~/Documents/DAZ 3D folder.
    Hope this helps.
    / Totte
    sorry: crossposting ;-)
    Post edited by Totte on
    After installer completed, I got this when trying to install all the additional content...
    685 x 552 - 99K
    1777 x 1279 - 1M
    edited April 2014
    You should use the little cog in the corner of the DIM window and setup where things are to be installed.
    And if you check |x] Show details you will see what destinations are available, and if you lack some, you use the cog to set them up.
    Right. It's all installed now. Whew. Thanks guys!
