Iray stopped working out of the blue
Hey all, so im rendering an animation, and after a couple of frames rendering stops, i check the logfile and it says no worker to render with (not allowed to fall back to CPU, iv turned that off)
So i close daz3d, open it again, try it again, preparing scene for ever (same in log file, no worker to render with.) i notice somewhere in the logfile that it wants to allocate 600gig to the graphics card......
i fire up the beta, load the scene, and rendering it fine....
Whats going on? Any1? thanks
Try rendering a different scene. If that works its an issue with that scene. If not then it's probably time to reinstall Daz.
Thanks for your reply.
Other scenes are fine, but there must be something off in daz, since the beta renders the scene fine, while the released daz wont render it..
If you disable the cpu fallback and don't have enough memory on your GPU to handle the scene it simply won't render or you will get half renders ect. I noticed the same thing. annoying thing is my renders could take (10 minutes with the gpu pushing) but with CPU fallback it's way past 30 minute mark.
