ED's Brick Shader (Iray)
1x Iray MultiMaterial/OnClick-Shader-Setup for your imported LeoCAD Model
81x Solid Plastic Brick Iray Shader
57x Special Plastik Brick Iray Shader
23x Transparent Plastik Brick Iray Shader
Build with DAZStudio4.10
I hope you enjoy this freebie. Commercial render are OK. I would be happy about a mention or feedback.
You are not allowed to sell this product in any way!!!!
Post edited by Chohole on
Hi Ed,
Check out #07! in the COUNTABLE FREEBIES: list. I use these shaders an awful lot! They are fantastic! Thank you very much for sharing these!
https://www.daz3d.com/forums/discussion/comment/5868671/#Comment_5868671
Greetings, JackyBrown
You are very welcome!
Thanks so much for these! I use them all the time.
You are welcome!
thanks a lot! just discovered leocad and this shader pack is an absolute must! very appreciated! ^^
You are welcome!
