Artifacts when using Extreme Closeup Smokey Rebel Makeup
Hello,
I've been using this product: https://www.daz3d.com/extreme-closeup-smokey-rebel-makeup-for-genesis-3-and-8-female-s
Lately, it generated the odd artifacts shown in my attached image.
Any idea what might be causing that or how to fix?
Thanks!
  • SevrinSevrin Posts: 6,314
    What character are you using it on?
  • DarkRepastDarkRepast Posts: 226
    Only way I found to fix it was to do so in post production. That was pretty inconvenient considering how large the area is that's messed up.
    I blasted it with light just to be sure it wasn't a weird shadow or something. And it wasn't. It's some kind of error on the surface.
    edited August 2020
    I don't own Pepper, but it looks like there's something wrong with the material not matching the character.  LIE make-up can't do that.  It just adds a layer on top of the existing layer.  It's a PNG that's transparent in the areas where your image shows the face breaking up.
    I loaded three of the raccoon-type Smokey Rebel eye shadows and some lips to show it's not the make-up.  I doubt it's a problem with Pepper either, though.  She's been around for a long time and so has the make-up.  Maybe uninstall and reinstall the character?
    889 x 1440 - 716K
    1340 x 533 - 34K
    Post edited by Sevrin on
  • FenixPhoenixFenixPhoenix Posts: 3,202
    edited August 2020
    Hello,
    Thanks!
    This happens when you have a LIE adding a partial normal map layer on a character that doest have a normal map. Simply remove the normal map (which should be a transparent layer) and the artifacts will be gone.
    Post edited by FenixPhoenix on
    Hello,
    Thanks!
    This worked!
    Thank you very much! I appreciate it!!!
