A7 EVA Luna Suit for Genesis 8 Female
So currently I am working on a Sci-Fi Suit called the A7 EVA Luna Suit for Genesis 8 Female.
So the suit also comes with a Lunar environment a life sized Moon Large and small Base Dome, a sattelight Base, a tower light and landing strip. Plus a lunar surface and lunar mound.
So far the A7 EVA Luna Suit for Genesis 8 Female comes in 4 unique syles, red and yellow, blue and white, yellow and black, purple and orange. Plus you can mix and match the styles to make your own, or the Suit also comes in a completely White colour that you can use to change the outfit to whatever colour you want. like HOT pink.
Any comments or crticues welcome.
Thanks. :)
  • KA1KA1 Posts: 1,012
    Looking very good indeed! Just some observations or odd thoughts the sprung into my head while looking through the promos. My brain is struggling to resolve the butt exposure, not sure why but for some reason I keep getting drawn back when I notice it and to me it feels a little odd. With the knee joint exposure on the bottom half of the suit my brain is expecting similar for the elbow joint or vice versa, I think it's the trying to resolve if the exterior of the suit is flexible, i.e. it's fine for the elbow joint to move in but not the knees? This are just silly not picky "thoughts" that crossed my mind looking through the pictures rather than full on critique, it still looks great.
  • Thanks KA1, good points. I will look into them further. :) Thank you very much.
  • AnEye4ArtAnEye4Art Posts: 864
    My only critique is the jet pack - it looks too small and under-powered. Could you make it a tad bigger with up / down controls?
  • LeanaLeana Posts: 13,150
    I had the same reaction. The knee joint being a dfferent material made me think the other material had to be rigid, but then the character wouldn't be able to move her arms and head as there are no "joints" for shoulder, elbow and neck.
  • Thank you all for your input. I will make it better. :D
  • SevrinSevrin Posts: 6,314
    Rocket boots!
  • So I changed the outfit to be more acurate and useful. the sholder and neck area and elbow area and now flexable so that the character can bend.
    Im also going to keep the rocket boosters as they are, since my main point in using them is only to give a boost for the suit wearer as the suit is mainly for moon walking in low gravity enviornments, they are not ment for long sustained flights.
    Thank you all for your help. :)
    1000 x 1300 - 249K
  • Is the suit one piece or does it come as components so you can, for example, remove the helmet while wearing the rest of the suit? Or take off the torso portion of the suit while wearing the leg portion of the suit.
  • It comes in Parts. there is the body suit that is worn undernith everything, then there is the helmet, arm guards, leg guards and torso plate. plus boots and gloves and the jet pack booster. Also a right and left leg holster that can be fitted alone or with the laser blaster that comes with the outfit as well.
    edited August 2020
    Agree on the rocket boosters, I had assumed they appeared for minor low gravity adjustments/stabilization kinda thing so already though they looked logical. Quick query though, not a big issue but still was a sticking point from my opinion, is the butt still exposed? *Edit to correct gravity (from a random autocorrect to grave!!!)
    Post edited by KA1 on
    The booster was the one reason I was interested. No big deal. I wish you the best with sales.
