v9.0 -- mcjBuilderA - script to build anything in Daz Studio - updated sept. 16 2017
12467…11
  • zawarkalzawarkal Posts: 1,018
    thanks for the explanation casual, I got the lathe working
    I was trying to put the turn 360 code in the same window as the obj window, once I realized they were two different windows of commands it worked
  • mCasualmCasual Posts: 4,607
    edited April 2014
    here you see the 2 latest commandswehich will be available in the next version of mcjBuilderA
    "break" which lets you break the extrusion flow and therefore create many meshes using 1 extrusion script
    "profile" which lets you change the extrusion nozzle/profile
    ( changing the profile will also cause a break, at least in this version )
    fig 3 - the streetlights heads were not made with mcjBuilderA but hey ( that "but hey" explanation is always so handy! )
    fig 4 - oh my, real life!
    584 x 596 - 77K
    1920 x 1080 - 648K
    595 x 335 - 696K
    1920 x 1080 - 152K
    1589 x 1200 - 114K
    Post edited by mCasual on
  • Miss BMiss B Posts: 3,071
    WOW!! What more can I say.
    edited April 2014
    fency stuff
    there's 5 fence sections shown here
    each fence section was produced by a single run of mcjBuilderA ... next version
    i just want to add 1 more thing, a "material" statement
    then just make sure everything still works
    then post it next weekend
    or tomorrow!
    1920 x 1080 - 350K
    1920 x 1080 - 186K
  • RAMWolffRAMWolff Posts: 10,396
    DEMS so big ole's fence lights Casual! lmao
    edited April 2014
    not as big as spaceships though
    ( note the mcjBuilder-generated fence now has more than 1 material )
    impala =
    3dwarehouse car in .kmz format
    renamed to .zip
    unzipped
    converted from DAE to FBX using autodesk fbx converter
    converted from FBX to OBJ using autodesk fbx converter
    1920 x 1080 - 378K
    470 x 410 - 32K
    1920 x 1200 - 106K
    edited April 2014
    use the florce fLuke
    mcjBuilderA is probably too cryptic and wont be used by millions :)
    it wont scare anyone who used POV-Tay though
    define Tube len
    Ring
    Move len
    Ring
    defineEnd
    define plancheA z
    profile square
    MoldSize 1.5 7.5
    material matPlank
    setZ z
    setX 0.4
    setRot 0 0 0
    turn -10
    turn 20
    turn -10
    movey 0.75
    break
    defineEnd
    1920 x 1080 - 679K
    1920 x 1080 - 300K
    edited April 2014
    volute !
    adding the "TaperX" and "TaperY" commands to mcjBuilder's language
    ( the extrusion is taken as moving along the Z axis )
    not perfect to make a violin neck but not far
    1920 x 1080 - 256K
    edited April 2014
    and last but not least, the radius-tapering "taperR" command
    1920 x 1080 - 234K
    1422 x 788 - 115K
    Plavalaguna Lacuna Coil
    ( and thanks to Amy for submitting herself to the ridiculous things i have her wear )
    1920 x 1080 - 193K
    Oh, that's so so COOL!
    Could be used for shaping the top of a walking cane as well. :coolsmile:
    edited April 2014
    that's the user interface for the upcoming version
    i added code that checks if your custom path scripts contain errors
    and i added a "console" area that displays errors, warning and information
    figure 2 -- maybe like this rather
    916 x 548 - 65K
    943 x 606 - 76K
    Oh that looks nice. Look forward to seeing the next version. :coolsmile:
    edited April 2014
    we're working on it
    here as a test, Amy attempts to build Rome in a day
    background photo by Alexandre Duret-Lutz
    making groved columns is easy except the extremities of the groves which are like tubs
    mcjBuilder can help build objects with great UV maps but one can probably not escape doing some finishing touches in Blender/Hexagon/anim8or etc etc etc
    1920 x 1080 - 1M
    1920 x 1080 - 345K
    1920 x 1080 - 645K
    edited April 2014
    see the cap of the groved column
    i had to triangulate it "manually"
    else Daz Studio was not loading the whole 400-sided polygon
    so the last thing i want to add is minimal triangulation
    which wont work too well for many concave shapes
    but happened to work well with this one
    1920 x 1080 - 1M
    1920 x 1080 - 786K
    1920 x 1080 - 645K
    1920 x 1080 - 252K
    edited April 2014
    good news 1 all the changes to mcjBuilder didnt destroy its ability to do frames
    good news 2 i aim to release the new improved version today
    things to do before that's a reality
    - triangulated caps
    - make sure the user cant get stuck in infinite loops
    - update the manual for the many new options
    - make sure old paths still work
    for the next version after that, i'll add profile caps, because for now mcjBuilderA can only do path-caps
    ( though the profile .obj files are usable as profile caps )
    there's always the possibility that .... sunday ... ya know
    also since everyone was worried seeing Amy lie on hard surfaces so i got her a rose bed of fake velvet
    1920 x 1080 - 328K
    edited April 2014
    see in a few well planned lines one can do neat things!
    and you can see i added a function that produces triangulated caps
    that fit the extrusion path
    1920 x 1080 - 121K
    1600 x 600 - 65K
    1600 x 600 - 104K
    All I can say sir is, you're a genius when it comes to this stuff. :coolsmile:
    minutes we're minutes away from Beta 2 ! :)
    the manual is done .... well it's updated ... someday it will be tidy
    https://sites.google.com/site/mcasualsdazscripts3/mcjbuildera
    just have to package the script and the new profile shapes i added in a zip file
    and create a distinct icon
    edited April 2014
    mcjBuilderA Beta 2 is ready !
    it's still Beta which means it's safe for me :)
    i will improve the manual very soon
    the examples
    though if you read this forum thread you can see the code snippets i used to create all the wonderful things
    600 x 337 - 40K
    Thank you kind sir. :coolsmile:
  • nakamuram002nakamuram002 Posts: 827
    Casual,
    Is it possible to wrap an object around another object using your script? An example would be a rope around a log.
  • caravellecaravelle Posts: 2,791
    Thank you very much!! :-)
    Casual,
    if the log is a perfect cylinder then it could be done using the Turn commands and a non-zero value for "slope"
    if the shape of the log is irregular,
    theres my script mcjRibbons
    https://sites.google.com/site/mcasualsdazscripts/mcjribbons
    instead of programming the path of the extrusion using a script/text, you animate a null node "by hand"
    there's also the possibility of using https://sites.google.com/site/mcasualsdazscripts2/mcjcolliderds45
    to help you animate the null node by projecting it on the log
    https://sites.google.com/site/mcasualsdazscripts2/mcjtransport can also be used to create tubes
    also mcjSuperLathe
    using mcjBuilderA
    - set the Profile to "g_round"
    here's the mcjBuilderA path script for the object shown below
    the log has a 20cm diameter
    Tread 100
    MoldWidth 10
    MoldHeight 10
    stepangle 30
    slope .4
    radius .15
    setY 20
    setZ .15
    rotateX 90
    Ring
    Move 20
    Ring
    turnX 1440
    Move 2
    Ring
    1242 x 582 - 85K
    later today i'll post version Beta 3
    Using Beta 2, the list of parameters that accompany user-defined commands can only have 1 parameter
    Beta3 allows an unlimited number of parameters
    i've been improving the manual with more complex examples ( see below )
    Beta 4 will fix the UV maps issues which i think happen for builds made of multiple objects
    1654 x 984 - 286K
    Gracias for the new update Casual. Very nice! :-)
    Thanks Casual!! mcjRibbons looks intriguing. More scripts to add to my toolbox and to learn from...
    edited April 2014
    - * - * - Update - mcjBuilderA Beta 3 ! - Update - mcjBuilderA Beta 3 ! - Update - mcjBuilderA Beta 3 ! - * - * -
    an important update that fixes some issues with the define and the Slope commands
    also the web page / manual is pretty complete !
    more things created during the writing of the manual
    1642 x 1040 - 269K
    Got it... now one other request. Is it possible to have the manual in a downloadable PDF?
