• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
How do you move your figure in Blender?
DinkelTwinkelDinkelTwinkel Posts: 4
August 2020 in Blender Discussion
I only know how to move the figure with Pose mode, with the giant gizmo at their feet. Is there a way to move them in Object mode? Doesn't seem to allow it. Or turn the posed model into a static mesh?
  • the5amkebabthe5amkebab Posts: 103
    August 2020
    You can use the x, y, z coordinates in the object panel or you can use the lazy viewport addon which gives you a similar control on the object as Daz does when you press "g" (move), "r" (rotate) or "s" (scale). I can't find the link right now but I think its on Github, I'll take another look later if you don't find it in the meantime.
  • marblemarble Posts: 7,500
    August 2020
    I've searched "lazy viewport" and found nothing. Any other hints?
    August 2020
    Found it.
    https://github.com/cgfasttrack/lazyviewport
  • Cris PalominoCris Palomino Posts: 12,557
    August 2020
    What are you hoping to accomplish by moving the figure? I must warn you that if you move the figure in object mode, it will change the location of the origin point and that can mess things up.
  • DinkelTwinkelDinkelTwinkel Posts: 4
    August 2020
    Basically I have a big scene and my figures have objects attached to them; Like Weapons and clothing. When I moe a figure I have to do it separately at the moment because object move doesn't work.
    August 2020
    Oh you are right, my figure turned into Mr Elastic :0 Do you guys know any other to move my posed figure into a different position my scene with the objects and items attached?
  • andya_b341b7c5f5andya_b341b7c5f5 Posts: 694
    August 2020
    What method did you use to transfer the figure/scene to Blender?   There are several possibilities. Knowing this would help to explain the 'giant gizmo' you talk about, and also what the best way to get the props and weapons to move with the figure.  Screenshots of what the figure looks like when it arrives in Blender may also help.
  • margravemargrave Posts: 1,822
    August 2020
    Are the objects and items parented to the model? Because they should move along with it. If not, there's any number of things it could be.
    Check the constraints panel to see if the objects are being prevented from moving.
    Press "N" and see if "Affect Only: Origins" is ticked.
    Look for any purple data fields, which means a driver has locked the property.
    August 2020
    Wait I will check. By Giant Gizmo, I mean the circle with 4 arrows coming off of it. At the feet of the figure, used to move everything at once,
    August 2020
    That sounds like Rigify, which is an add-on for Blender that creates an advanced armature beyond the Blender default. I believe it automates some of the posing with drivers and the like, which might be why you can't move it. I'm not familiar with it, but if you search YouTube for "Rigify" you'll find tutorials about how to use it.
    September 2020
    Hi my friend found the solution to this problem. Turns out it's simple, For some reason transformations are all locked by default in the import. Select the Armature in object mod, Click N to slide open the menu on the left of the viewport. Click on the Item tab, click transform and unlock all the transformations.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
