How to Swap Body Parts Between Characters
anthony.luigi_05ebfcd7e7
in New Users
Hello,
Is it possible to swap certain body parts between to like character (G8F -G8F)? For example, can a swap a mouth I like from one to another, or eyes shapes, nose individually?
Thanks In Advance!
you need to use Dformers.
There is a product that simplifies this - Shape Splitter: https://www.daz3d.com/shape-splitter
That needs a little amplification. One way to split a morph that isn't already split is to createa dForm, give it a weight map that selects the area you want to keep and has a smooth fall off around it, then export the figure alone with the unsplit morph applied and at base resolution, and finally load that through Morph Loader Pro selecting the dForm in the Attenuate By section - in other words the dForm is just a carrier for the weight map.
