v9.0 -- mcjBuilderA - script to build anything in Daz Studio - updated sept. 16 2017
13567…11
  • V3DigitimesV3Digitimes Posts: 3,497
    I'm just discovering this post!
    It reminds me of the "goto" I learnt when I was a child. It seems very funny!
  • mCasualmCasual Posts: 4,607
    edited April 2014
    must be the "turtle graphics" part of the LoGo language
    i didnt know they actually were controlling a robot turtle with it
    http://en.wikipedia.org/wiki/Logo_(programming_language)
    640 x 869 - 292K
    1920 x 1080 - 363K
    Post edited by mCasual on
    edited April 2014
    radius 0
    turn 360
    .... and .... that's called a lathe !
    so i create this path curve using mcjBuilder
    and i export it as an .obj, ..... in the profiles folder
    i also save it as a path curve
    hardturn -90
    Move 3
    hardturn 90
    Move 3
    Radius 4
    turn 45
    radius .05
    turn -90
    Radius 1
    Turn 90
    radius .05
    turn -90
    Radius 2
    Turn 45
    Move 4
    Turn 45
    radius .05
    turn -90
    Radius 1
    Turn 90
    radius .05
    turn -90
    Radius 4
    turn 45
    Move 3
    radius .05
    turn 90
    Move 3
    Ring
    i close mcjBuilder and re-open it, so that it can "see" my new extrusion profile
    i select the column profile
    i create this path ... which should give us a lathe behavior
    Radius 0.0001
    turn 360
    and it worked !!
    the step Angle was 22.5 degrees so it's a bit rough
    there you have it, all done in the confines of Daz Studio!
    you could obtain something similar using mcjSuperLathe or mcjJathe
    except the profile would be splines instead of circle arcs
    1280 x 720 - 72K
    1280 x 720 - 59K
    1200 x 1200 - 56K
    1200 x 1200 - 97K
    309 x 296 - 5K
    When I was told that LoGo was powerful I did not believe it. Maybe now I can change my mind ;)
    edited April 2014
    by the way you can try LoGo online right here http://www.calormen.com/jslogo/#
    if you copy and paste
    TO square :length
      repeat 4 [ fd :length rt 90 ]
    END
    clearscreen
    repeat 36 [ square 50 rt 10 ]
    if draws a star
    the "TO Square: length" statement means
    "if someone mentions the word "square" and a number
    then, lets call this number "length" and do the following ...."
    the word "END" puts an end to the definition of what it means to "square"
    repeat 4 [action] means repeatedly do the bracketed action
    fd :length means : move forward "length" number of pixels
    rt 90 means : turn right 90 degrees
    i may add a "repeat" command to mcjBuilder
    612 x 602 - 83K
    1010 x 632 - 80K
    edited April 2014
    making a wrought iron scroll using mcjBuilder and the Fibonacci sequence (1) 1 2 3 5 8
    1920 x 1080 - 669K
    1920 x 1080 - 1M
    1286 x 766 - 191K
    that's at the “Mardan Palace Hotel , a crazily expensive big hotel i gather
    957 x 1274 - 1M
    uh hum
    ( but it does show i was able to fix slight problems with the "turn" command )
    1920 x 1080 - 1M
  • RAMWolffRAMWolff Posts: 10,394
    HAHAHA.... That's cute!
    edited April 2014
    this spring scroll hairstyle
    unless it's called ionic
    800 x 600 - 58K
    1920 x 1080 - 1M
    1920 x 1080 - 1M
    hahahaha.. *FALLS OVER*
    edited April 2014
    See the sort'of visor-tube? there's upward arcs of circles ... next version of mcjBuilder
    it should be very versatile so you can bend the mouldings anyway you want, which will include twists/screws/coils
    1600 x 800 - 288K
    1920 x 1080 - 993K
    1920 x 1080 - 302K
    1920 x 1080 - 693K
    1920 x 1080 - 831K
  • Miss BMiss B Posts: 3,071
    ~ROFLMAO~
    Seriously though, that would make a great top to a column, as your third image shows.
    edited April 2014
    the turnUp action .... next version soon
    there'will also be the "Update" button
    lets say you created a custom extrusion path
    and you built an object called "tubularBell.obj"
    you loaded it in the scene using the "load" button
    but the result is not exactly what you wanted
    normally you'd
    save your custom extrusion path
    close mcjBuilder"
    delete the object from the scene
    re-start mcjBuilder
    tweak your path
    press the build button
    press the load button
    but now you'll just have to do:
    tweak your path
    press the update button
    the script will delete the old version if it's in the scene
    build the new one and save it over the old version
    load the new version in the scene
    calli WYSIWYGBYHTPAB which means ""what you see is what you get but you have to press a button"
    fig 3 problem adding the "twist" movement
    fig 3. twist ...works ( quaternions may have to be used )
    fig 4 now i get it ! the extrusion nozzle faces forth, the twist axis also faces forth
    figure 5 there you go - turn means "turnY" means turn around the Y Axis. Slope means, .... and move along the Y axis by this much
    1920 x 1080 - 218K
    1920 x 1080 - 208K
    1920 x 1080 - 116K
    1920 x 1080 - 58K
    1356 x 755 - 129K
    edited April 2014
    implementing the Turn + Slope effect for all 3 axis
    radius 2
    slope 30
    turnUp 3600
    and you know what else one could do?
    parent the null-node that transports the extrusion profile
    to an animated node
    and what would you get?
    a coiled guitar cord
    figure 2 .... oops actually as it is presently it wont work ( but it will )
    1920 faces, hexagon profile, 14400/45 = 320 little tubes
    fig 3 .. it now works but there's a shear effect and the parent node cant really steer the extruder
    fig 4 - Scale effects using a parent node trick
    fig 4: tada ! i set "slope to 0 so the parent node is the sole control for the extruding nozzle position and heading - mcjBuilder is what spins the nozzle to give us the coiling - note that mcjCycleFilter was useful for regularizing the parent node animation
    1920 x 1080 - 74K
    1920 x 1080 - 259K
    1920 x 1080 - 143K
    1920 x 1080 - 234K
    1420 x 790 - 78K
    edited April 2014
    i'll probably post that object on my site
    927 x 1199 - 321K
    927 x 1200 - 259K
    1920 x 1080 - 174K
  • atticanneatticanne Posts: 3,009
    Curly phone cords and water hoses are great to have.
    edited April 2014
    note that mcjTransport and before that mcjRibbons could be used to do spiral cords and cables
    http://www.daz3d.com/forums/discussion/7278/
    1280 x 720 - 157K
    1280 x 720 - 171K
    edited April 2014
    the upcoming version will have a setScale, setScaleX setScaleY, setScaleZ command
    1280 x 720 - 78K
    1280 x 800 - 94K
    edited April 2014
    the next version will also have a simple repeat command
    only 1 level, meaning you cant have a repeat within a repeat ( for now )
    fig 2 uses the fuzzy wuzzy shader by Marianne
    http://www.sharecg.com/v/36638/View/6/Texture/Fuzzy-Wuzzy-Fur-Shader-Daz|Studio
    1280 x 720 - 34K
    1280 x 720 - 68K
    1413 x 787 - 56K
    edited April 2014
    .... and the next version will include the "define" command
    which lets you give a name to a block of commands
    for example here i defined something called a Bob
    which creates a B shape
    once it's defined
    i just have to issue the command : Bob
    define Bob
    ring
    Move 1
    radius 3
    turn 180
    Move 1
    radius 1
    turn 180
    Move 1
    radius 3
    turn 180
    Move 1
    radius 1
    turn 90
    Move 8
    turn 90
    Move 5
    Ring
    defineEnd
    repeat 5
    Bob
    repeatEnd
    figure 2 - using the superShine shader by Marianne
    http://www.sharecg.com/v/31573/Material-and-Shader/Super-Shine-Shader
    so as we speak the available commands will be
    repeat
    repeatend
    define
    defineend
    slope
    radius
    rotatex
    rotatez
    rotatey
    setanglex
    setangley
    setanglez
    setscalex
    setscaley
    setscalez
    setscale
    ring
    hardturn
    turnup / turnx
    turn / turny
    twist / turnz
    movex
    movey
    move / movez
    moveto
    the define command will also accept a named parameter
    example
    define Bob n
    ring
    Move n
    ring
    defineEnd
    Bob 3
    1280 x 720 - 430K
    1280 x 720 - 145K
    edited April 2014
    i digress but mcjBuilderA can be used to animate nodes which can then be used by mcjAutoLimb to create foot targets
    (walk inspired by seeing "Happy Wheels" gameplay )
    640 x 240 - 314K
    edited April 2014
    braids !
    you can already do braids using the current version
    but here i used the upcoming "define" and "repeat" commands
    figure 2 - without SubDivision and texture/displacement
    figure 3 - you have 1 day to moddel that hairdo ... kidding :)
    728 x 1098 - 125K
    1280 x 720 - 178K
    1280 x 720 - 132K
    possibility that i'll post the version i have today!
    600 x 337 - 40K
    Awesome works Casual. Been busy setting up Chrome and finding my threads to subscribe. Have a great day. Hoppity hop hop hop
    Ohhhhh, I hadn't realized you can do braids with it. That's going to be sooooo kewl. :coolsmile:
  • zawarkalzawarkal Posts: 1,018
    I have been trying to use the example where you created a path and then lathed it using the radius 0.0005 and turn 360 commands
    I cannot get this to work and I'm not sure what I'm doing or not doing
    Would it possible to get a step by step of how to achieve this?
    edited April 2014
    in this first version, it's important to use only the Tab character to separate the words and the numbers
    so
    turn[TAB]360
    works
    but
    turn[Space]360
    does not
    in the next reply i'll do the step-by-step test ,
    my recent examples were done using the upcoming version
    but the "turn" command did exist in the version you have i'm pretty sure .... to be continued
    edited April 2014
    step by step test
    i start the mcjBuilderA ( version dated 14 April 2014 )
    i click on the "defaults" button
    so the program returns to its factory settings
    i delete everything in the text area
    i type
    turn[TAB]360
    i click on the "Build"" button
    after 2 seconds the program asks me a location and file name for the .obj file
    i put mine in i:\aoa\mesh.obj
    now the object i built is on disk
    i click on mcjBuilder's "Load" button
    i look in daz studio's scene tab and i find a new node named mesh0
    i zoom to it
    it's quite small, below you can see it near a sugar cube
    the default extrusion profile was a circle
    and the default radius was 1
    so we get a torus/donut
    second test
    in the drop-down list i select the profile named
    "classic_cymaRecta11"
    the extrusion path script is still
    turn[Tab]360
    but i changed mcjBuilder's initial radius to 0
    i click on the mcjBuilder's "Build"" button
    i put in again as i:\aoa\mesh.obj
    and we obtain a lathe
    note that in the profile preview plot, the red cross
    indicates the location of the (0,0,0) origin - so the revolution is centered right there
    1418 x 756 - 207K
    1482 x 756 - 132K
    next version will allow the creation of multi-part models
    example,
    you extrude 4 square tubes
    that's the table legs
    change the extrusion nozzle for a bar-edge shape
    extrude a table edge
    add a cap
    and you got a good looking table
