Carrara Challenge VIII - "The Great Race" or "Don't Fence Me In" - WIP Thread is Open
1…6781012
  • DartanbeckDartanbeck Posts: 22,154
    diomede64 said:
    Philemo said:
    For the mesas, I've been unable to reach the idea I had. The difficult part was the erosion, which gave either too much or not enough effect.
    Eventually, I decided to stack 3 mesas on top of each other, so they could mix and give the required effect.
    Wonderful solution. It reminds me of stretches of New Mexico that I drove through on a summer trip, including the lack of a gas station. I just like writing "including the lack" because it seems contradictory.
    Not only are you not late, but there is still time for a second entry! :cheese:True story. Jam it out, Philemo! Rock On!!! And I think I'm actually going to finish mine before the deadline too! :)
  • AntaraAntara Posts: 444
    Wow. head wax, I love the colours in your image and the poses of the figures. It's almost a shame to blur them - they are so much fun to look at! But the blurring does add the humour and the sense of speed :).
    The entry thread is getting populated with great image, too! This is going to be fun! :)
    Here is my pre-postwork final render. I am posting the post-worked one in the entry thread.
    800 x 800 - 407K
    Almost there... I think...
    1920 x 1680 - 2M
    Aaahhhhhhh!!!
    Spectator: Did you guys hear something?
  • DUDUDUDU Posts: 1,945
    edited April 2014
    Post edited by DUDU on
    LOL!
    I love the particles system! Never really tried it before, now it's hard to set it down!
    In Dart's picture there is a guy on fire being blown away from the wreck. Nobody seems to see him. I was just filling in the dialogue. ;-)
    edited April 2014
    This is this final render prior to post work.
    The particles take quite some time to render... crazy buggers. But I really like the system. Fun to set up and quite diverse.
    The terrain on this one was a trip. But I think I spent more time on shaders than anything else.
    The main terrain shader - is using a layers list, with overlapping opacity masks to blend the various effects. This was a blast to work with. The final layer added is the light dusting of leaves across the whole scene. It was a challenge to get them as sparse as they are now. Mostly setting up the fractal noise generator with the right blend of contrast, brightness, and scale. Not to mention the right fractal shape. Once I got the distribution figured out, I cranked the bump intensity up to 500. The slider only goes to 250, but you can enter in higher ranges, but it automatically stops at 500. This super high bump value creates an effect that makes the leaves appear as if they're sitting slightly above the surface, which is what leaves do, due to their irregular shapes and curling affect from drying out. Unfortunately this whole feature gets lost in the motion of this image. But it all adds to the final outcome.
    Lighting the scene:
    Sun Light - For this piece I decided to used Carrara's Global Illumination. I began with a Sun light, aimed to light the whole scene, left the ambient slider in scene settings off, and turned on Gamma Correction, which I've set to 2.2, and enabled the Sun Light option, which turns on Carrara's Global Illumination.
    This simple setup works amazingly well on this terrain. In my opinion, the trees look quite natural, as does the rest of the terrain and its shader elements.
    Distant "Kick" Lights" - After adding the two vehicles on the road, I decided to give them some added kick from behind. For this I added a distant light and linked it* to just the vehicles, and later added the crowd of people, other (crashed) vehicle, and the emitted particles. I love using distant lights in this way, as their placement matters not, just their angle affects where they shine, so I can pull it right in front of my render camera and adjust the angle while looking through the framed image. So for this "Kick: effect I crank the brightness up well over 100, often 180, 200, or even higher sometimes. If this begins to over-power the scene, I simply change the angle of trajectory. Then it becomes a balance of how I want that light to effect the scene angle-wise vs how bright to make it. So I tweak accordingly. While it's fairly easy to get accustomed to constant values and approximate angles - so that, for example, I'm always using 180 coming into my scene around 23 degrees off center, it's much better to take time with this light and set it specifically for each scene.
    Once the accident occurred, I added a second distant kick to simulate the illumination from the fire on certain subjects, just for added kick - in addition to the lighting of the flames. So I made this one highly saturated orange, very bright, and linked it to the exploding air bike, its ejected rider, and the crowd of spectators. Again, I kept this mostly aiming into the scene from behind everything, just to add some kick to the lighting already applied to the flames, so that I didn't have to try and make those lights more than they needed to be.
    * Linking Lights - means that they only affect that, which they are linked to. In Carrara this is handled at the top of the General tab by two radio buttons: "All Objects Except:" or "Only:" under the "Restrict Lighting To:" pane, with the handy "Add/Remove" button to select objects to be included or excluded from the light, depending upon which radio button is chosen. So If I select Only: This Box, for example, I have just 'linked' This Box to the light, and only This Box will be affected by that light.
    Shape Lights - Carrara 8.5 has truly opened me up to using these. Let's face it, it just isn't any fun using a shape light if you can't really see what it's doing. Or maybe that's just me. Having the new shapes to go by, I'm having a lot of fun experimenting with them, and thanks to Jeremy Birn's book, learning a lot about their use. Something I've never known: Spot lights and bulb lights originate from a single point, no matter how they end up. Shape lights originate evenly across the shape. So for the fire, being a still scene, I added two oval-shaped discs of light - one for either side of the air bike. This makes the main orange glow from the flames originate from slightly larger than the space of the flames, and then cast outwards according to their angle and settings. Shape and Tube are the only types of light I know of in Carrara that allow for different types of falloff algorithms: Linear, Distance Squared, or Logarithmic.
    The Realistic Sky - was meant to be drab. So I used three cloud layers with high 'coverage' settings. I kept working the cloud layers until most of the sky was covered up by one layer or another - preferably all three in combination, what is where I ended up with. I really like playing around with the various controls in the realistic sky editor. Automatic fog, with variable altitude and denseness, is just a great feature to have for hiding an otherwise barren horizon. Combine that with some clouds and... bam! I know that the clouds in the RSE get a bad rap from some users. Perhaps there are other issues at hand. But I think that the clouds are quite useful, are very fast, and add to (or rather - take away from) the global lighting, as they should, while still being fast... that's pretty cool. Let a few of these fill up the background sky, and plunk in a single, large and dispersed volumetric cloud to add the fluffy, fine details that they add. One of my favorite features of the RSE, however, is how nicely it allows us to set the lighting simply by setting where the sun is in the sky. That's just cool.
    Particle Emitters - I set up the first emitter using a gradient shader controller by the life of the particles and an alpha mask image. I left the particles somewhat large, at 5' plus or minus 3' and kept the number emitted per second down to 300, which turned out just the way I wanted it. I also set the gravity in the advanced tab of the emitter to x=2, y=1, z=-1, to keep the smoke rising and to get it traveling. I duplicated that emitter twice, and changed the size and dispersion levels as well as the rate and lifetime settings, but left the gravity the same. The final emitter was attached to the crashing guy back by the road. I changed and tweaked the settings on that one quite a bit to get the effect the way I wanted it. I animated the man to touch the edge, about where he would be on his bike when it crashed, and then hurled him up and over the wreck to where he is now. I used to race motocross, and I've seen a few (and done a few, myself) cool crashes where the rider is launched, flying through the air like that, from the flip of the seat of a bike doing and 'endo', which is short for end-over-end, most commonly referring to going over the bars frontwards, not back. So I followed his path along the timeline and tweaked it until it looked right. The final render is five frames before the end of the animation. More specifically, I went five frames past my final render scene end marker to animate where the guy was flying to. This keeps the tweener from ending on the last frame. I often go much further that five frames, but this was a case where the whole thing was happening in a split second - so five frames was plenty! ;)
    1920 x 1680 - 3M
    Post edited by Dartanbeck on
    edited April 2014
    Thanks Antara,
    Well there is some amazing work here !!
    Just to mention the last two....
    Loving Antara's emotive take - it's a visual poem in a metaphorical sense. Metaphors abound. And really interesting use of the terrain editor.
    Dartanbeck, that's an amazing render, really professional. I bet you'd ;ove to blow things up for a living :)
    Stezza ... brilliant work :)
    thanks diomede 64 and mmoire :)
    Post edited by Headwax on
  • SileneUKSileneUK Posts: 1,980
    edited April 2014
    Philemo said:
    A late entry for the challenge but, AFAIK, I'm still on time.
    I wanted a desert scene and I had a clear idea of what I wanted.
    I couldn't make it in one terrain and, so, I ended up with five :-)
    There is the front terrain, a back terrain (dunes) and the mesas.
    The pictures are :
    - the final background that will be used for the scene, no postwork.
    - Terrain distribution
    - 3 different settings for the mesas
    Hiya Philemo,
    Late to comment on this...but am grateful for the clear steps you show in creating your terrain. It's a great addition to the tut that Dart started on making terrains a couple of weeks ago. I find working with the Carrara terrain map tool a real challenge that will require a lot of practice.... but it's so useful and versatile it will be worth it..
    Cheers, for this!! xx :) SileneUK
    ETA I LOVE all these WIPs, when I look at the entry thread... I scratch my head about the need for so much post work. They look so amazing when the details can be viewed...JMHO. ;)
    Post edited by SileneUK on
    edited April 2014
    ETA I LOVE all these WIPs, when I look at the entry thread… I scratch my head about the need for so much post work. They look so amazing when the details can be viewed…JMHO. wink
    Post work is your friend - (obviously it might not be my friend :))
    If an artist learns post work then they are going to save themslves a lot of mucking around in the long term. Lots of new artists think one tool eg Carrara can do everything..... unfortunately not true . It's a lesson lots of people don't learn.
    At the very least, post work can give you lost and found edges.
    At it's very best post work can help us lose details
    Some of us want to lose the details.
    To misquote Richard Schmid, 'people think that artists have this wonderful gift for seeing more than what ordinary people see, but in truth a good artist sees less.'
    That is, it's all about suggesting what is there as opposed to describing everything in detail so the viewer has nothing to contribute to the 'conversation.'
    The other side of the coin. ;)
    Oh I know... I use PS all the time and along with Illustrator it has been my bread and butter for 10 years! I am just amazed at the detail and quality of the Carrara work, its products, and the artists' created material I see here. Yours especially included.
    Post Work is valuable and necessary for defining expression or muting it, adding useful content that would be 3D problematic / time consuming, and giving that finishing touch. I just love seeing the real images from the viewpoint of someone who is learning Carrara and am so impressed by what can be achieved just using its tools.
    Definitely agree that in the real world that artists should not spend time trying to get Carrara to do what PW would do easily as well or with more effect. I add 2D elements to my scenes all the time. Some subtle, some not. I wasn't ready to create a 3D group of voracious ravens or vultures harassing the hunters or cave lion, or adding more lichen for the reindeer on the grass to graze, or more haze in the mountains, in my entry....so I didn't bother as it would have taken forever and may not have looked right. I thought of doing them in PW, but was happy enough as a newbie not to over-do the scene. Just entered for fun and to hopefully see other newbies join in.
    Cheers! xx :) SileneUK
  • DiomedeDiomede Posts: 15,467
    Just a quick reminder that the entry thread will be converted to the voting thread in a couple of days. Some wonderful WIPs have yet to be entered so this is just a gentle nudge, and a not so subtle attempt to keep the Challenge post near the top of the forum.
    On a different note - Hey, Headwax and SileneUK! What is with reaching an amicable understanding and mutual respect? There shall be no harmony in this WIP thread.
    So, to get the pot stirring again, there seems to be a lot of focus on how light particles “really” bounce, and getting “realistic” skintones with subsurface scattering, and how the periphery appears blurred in the “real” world. Well, to using “reality” as a guide for art, I quote “Without art, the crudeness of reality would make the world unbearable.” (George Bernard Shaw) So why should realism be valued?
    But, to the scoundrel who quotes Shaw in a Carrara WIP thread, I quote this description of Shaw, “It is his life’s work to announce the obvious in terms of the scandalous.” (HL Mencken) And to lurkers, I quote Shaw again “Silence is the most perfect expression of scorn.” But you already know how I feel about scoundrels who quote Shaw.
    Actually, I don’t mean any of that. I am very impressed by the images in the entry thread thus far. My eye keeps coming back to the cracks and shoulders of the road surface in Kashyyk's police chase, the balloons in Stezza's steampunk race, the flags in Varsel's ?horse? race, the drape of the body of the antelope in the bigcat's mouth in SilineUK's hunt,.... There is something in each image that interests me (except that cowboy with the rifle looking at the fence ;-) ). There are some elements of realism and some of pure fancy, but I enjoy them all.
    I want to encourage more enlightening posts like the discussion on postwork, but as for preferring allegory, or realism, or relying on a single tool (whether it be charcoal on a cave wall, oil-based paints, or a 3D program) even though more tools are lying around, or emphasizing humor, nostalgia, or even sentimentality, or making a social or political statement through art –
    De gustibus non est disputandem
    head wax said:
    Thanks Antara,
    I agree on all counts except for one thing, in that I am certainly not the pyrotechnic in the family! :)
    While I do love to watch them, setting them off has never been a thrill for me. Strange. Even at a young age, I'd leave the fireworks and blowing up of things to my brother and friends. Never a fear of them or anything like that, just that I never really felt the urge to be the one doing it. Playing my drums? Yeah... now that thrills me! :ahhh:
    On the other points... yeah... very nice work going on here... wow! I'm loving the entries and the WIPs! Brilliant!
    edited April 2014
    Oh Dio Mio....You must be a philosophy professor in your off-board life or extremely well read.... because you aren't a zoologist! They are caribou/reindeer. There ya go, some argy bargy for the arty farty contingent! And a big hug, you are being a brilliant challenge host and no I am not sucking up.....much. erm maybe I should as I am not really a blonde anymore! ;)
    %-P xx SileneUK
    edited April 2014
    Agreed. Diomede64, You truly are a brilliant contest host.
    Last night I didn't have enough time to type much into my last WIP post, so I've updated it with Lighting WIP information.
    I updated it again with more thoughts around the making of this scene.
    When I entered my image to the Entry thread, I noticed that folks where linking to their WIP posts. In finding my few posts among so many pages, I've seen a lot of stuff that I've missed throughout the duration of the WIP stage of the contest, which is, in fact, still going. But I saw so much valuable information in here, that it made me recall how awesome and helpful each of these contest WIPs have been. I checked out my modest entry about my terrain height creation and, while I like what I've presented, I thought that I could do much more.
    This also brings up the value of being in, or even just observing these contests. I'll be going through and getting links to each of these contests and making an index to them for the information index thingy. There's a lot of that to do... I better just take a day or two off and get that done soon. Although I keep saying that, just know that this is not an empty promise. I do love indexing these things and other threads around here. It just takes time so I have to put aside a quite a bit of it to get enough done to be worth while. As active as the Carrara Discussion Forum has been since the release of 8.5, and just before... I have a lot of great threads to index! Very cool! It's coming... and it's coming soon! ;)
    edited April 2014
    This will be my final WIP for this image. I do have another idea that may come together a little more quickly, so we'll see if I can squeak it in before the voting begins. If not, then I'll post it in the render thread.
    I edited the shaders on the tombstone to get them a little closer to how I envisioned it. Speaking of shaders, I'm very happy with the shaders on the fence pickets. If anybody wishes, they can DL it from Dropbox. They were set up in a medium sized scene, just so you're aware that if you use it in a large or small scene, the scale of some the effects may need to be changed.
    https://dl.dropboxusercontent.com/u/7370483/Old-painted-wood.cbr
    The scene was set up with an inserted terrain which I adjusted somewhat. The terrain was one that I had made for another purpose and tweaked for this entry. Because only a small portion of the terrain would be visible, I used the 3D paint tool to paint a distribution map for the spline grass I made. The carpet moss is a re-purposed model I made a couple years ago out of meta-ball objects, dynaimc hair and a surface replicator for the spore thingies.
    I used a realistic sky and volumetric clouds for the atmosphere and rendered using the Skylight. I rendered a depth pass, which I used to add a DOF in Photoshop. I wanted a bit of a foreground blur, so I selected some grass clumps and "painted" them a light shade of gray to force Photoshop's lens blur filter to add a foreground blur.
    The first color image has no postwork and the last color image has the DOF added. I didn't do any other postwork to the image.
    2000 x 1236 - 2M
    2000 x 1236 - 806K
    2000 x 1236 - 2M
    992 x 758 - 202K
    I'm posting this separately because I didn't want to have it get lost in my last post.
    I just wanted to say that there are some really great pictures in this thread and the final entry thread as well. More importantly, the WIPs have some great explanations as to what is trying to be achieved and the steps that were taken to get there.
    It was also very gratifying to see some Carraraists participate in this challenge that haven't done so before. It takes a bit of bravery to put yourself out there. You have done yourselves and Carrara proud! To the newer users that entered, I'm especially grateful. These challenges were originally designed to try and entice new users to try some of the more complex or lesser understood tools Carrara has in it's toolbox. The challenges were never meant as a vehicle for the more advanced users to gain more bragging rights, but rather to foster interaction and learning amongst the community and to show off what Carrara can do, so that others that aren't familiar with this diamond-in-the-rough of a program may be inspired to try it and increase its sales and viability in the future.
    I know I'm not the host of this challenge, but I still want to say thank you to all posted WIPs and/or entries.
    I also wish to thank our illustrious host for a damned fine job. Let's also give some love to our fine sponsors!
    edited April 2014
    nicely said evil . Love that tombstone shader, looks like the real thing, which is scary :)
    sorry Lauren, I have spent a few years listening to people soap box about the evils of post work.
    by "evils" I don't mean evil producer's cousins
    I agree that postwork is your friend. There are times when it can be over-done, but that isn't a problem you seem to have. Great entry!
    edited April 2014
    flattery will get you everywhere
  • StezzaStezza Posts: 9,270
    agree with all the posts ... ;-)
    I love the shape of the Evil tree.. it's a shame more of it isn't shown in the render IMHO
    This month's challenge seems very popular.. I'm sure I did two WiPs for my 'Don't fence me in' render but bugger me if I can find them both.. lol
    Great job done by all..
    I tried to, but the framing didn't look right. I wanted more of an intimate scene and if I pulled back I lot the feel. I did save it and have other uses in mind, so don't be surprised if I make a Poltergeist scene. ;-)
    There's still time... get one in if you need another! ;)
    ~~ but the framing didn't look right. I wanted more of an intimate scene and if I pulled back I lot the feel.
    I can feel that too. As killer as the tree is, it's not the focus of the theme, right? The plus side... it looks awesome! Wow, Stezza has some really nice work in there too. So does HeadWax, Diomede, Silene... Okay... once again... I like them all! I'm also glad to see Totte in here. I think he's new to Carrara, but has been with DAZ for a while? Nonetheless, I'm glad that I was actually able to attend this time around. I'm really grooving on these contests. The final entry threads are fantastic, but the WIP threads are getting quite full of great inspiration for new techniques, with a final entry to enjoy the final result of the toils. Such a variety of different things going on each month... I'm loving this!
    Mike Moir, Thanks for sponsoring. And Diomede64, great job of encouraging folks to take part in your challenge, and coming up with the scenario. Very cool! Actually, I'd also like to thank all of the previous contest creators (and contestants) and the sponsors too.
    Yep, must be drinking to much Grange... we do that a lot in NSW
    updated post on page 16..
    http://www.daz3d.com/forums/viewreply/582261/
    North, South, Wisconsin? Must be where evilproducer's twin brother lives! :)
    This will be my last WIP for my Mad, Mad, Mad, Mad, race entry. I inserted a terrain, used Carrara's terrain editor to dig the hole, exported the map, used Photoshop layers to make the road, parking lot, and stream, as well as some shader masks, I then imported the adjusted heightmap back into Carrara's terrain editor and used a layers list to adjust the terrain shader for the parking lot and the stream.
    I used a lot of 3rd party content, including the palm trees from Lisa Botanicals, other foliage from LB, the cars are the 58 Impala and the 36AM Sedan, the bike is the BMX bike, one plane is from the default content browser and one is the Daz biplane. I had to retexture the 36am sedan to turn it into a convertible, and retexture the biplane to replace the RAF decals. The two human figures are Poser5Don and Daz's M3, both retextured, and I made a set of workman's overalls for M3.
    If I manage to squeeze in the time, there are more characters and scenes I'd like to pay tribute to, but the deadline will be approaching soon. I'd really like to get Ethel Merman in there if I can.
    Great job everyone. You made this a very enjoyable month for me.
    640 x 480 - 46K
    836 x 616 - 67K
  • GarstorGarstor Posts: 1,411
    Hahaha!!! My money is on "New South Wales."
    Great entries here, across the board. I'll have to ponder my votes carefully.
