How to make clothing object fit and follow in DS4?
Hello - I have a clothing item that works in poser, not dynamic, and I have tried transfer utility to make it fit and follow a v4 figure, but it hasn't worked thus far. I think I need to know what actions to take with the transfer utility to get this to work.
Any help would be appreciated.
Thank you
  • JaderailJaderail Posts: 0
    Have you tried Fit To? Right click and chose Fit to or use the Parameters Tab for the item Fit To should be near the very bottom.
  • PendraiaPendraia Posts: 3,629
    Thank you
    Hi, I'm unsure if you are using the v4 shape for genesis or the v4 figure?
    If you are using the figure the transfer utility won't help as v4 is not weight mapped...jaderail's suggestion should work an d you shouldn't need to use the transfer utility at all.
    If you have a cr2 file that you wish to use with the genesis v4 shape you should be able to use auto fit if the clothing is for gen4. If it is for gen3 you will need to have the gen3 shape for auto fit to work.
    As morphs are now transferring with auto fit you shouldn't need to use the transfer utility any more...
    Hope this helps
    Pen
  • DWGDWG Posts: 770
    Though only for people who have Studio 4.5 RC2 installed.
  • KickAir 8PKickAir 8P Posts: 1,865
    The current version of that is now RC3! :cheese:
  • edited December 1969
    Awesome, thank you all!
    edited July 2012
    The current version of that is now RC3! :cheese:Thanks for the link! : )
    Sorry I didn't think that they might not have 4.5 installed... : (
    If this was the case they would need the transfer utility...
    Post edited by Pendraia on
