Problem with the "trend setter" outfit
Hi,
I have been trying to use the "trend setter" outfit on a genesis 3 female character and at first I was successful...
But for some reason the shirt and shoes part of the outfit now look like this (see attached screenshot) and I don't know why...
I tried to use the "fit" tool but it only aligned and scaled it (apparently)
I'd appreciate any advice, I'm very new to this software
  • DDCreateDDCreate Posts: 1,424
    How did you install it?
    When that happens to me, it's normally because my textures aren't installed in the correct folder. If you did a manual install, I'd check and make sure you popped everything into the right drawer. If DIM installed it I'd say, have DIM uninstall and then re-install it again. Hope that helps. And it is odd that it's not effecting the pants.
  • That indicates that the asset files are not being found or are corrupt. How did you install?
  • MisarmorMisarmor Posts: 43
    I tried to install it and uninstall it both through DazCentral and Daz Install Manager... Note that the pants on the screenshot is from the same outfit
    I think I remmeber tryin gto use the "auto-fit" feature on a genesis 8 character (this si meant for genesis 3) before this happened. Is there any chance this has triggered this bug ?
