Rigging in DS 4.6.2.120 for use in Carrara
RoygeeRoygee Posts: 2,247
Hi all :)
Just curious whether anyone has recently rigged a figure in DS and exported as cr2 for use in Carrara?
I used to do this a lot because I much prefer the weight-painting and constraints setting. Haven't done it in a while, though, because I've been concentrating on hard body modelling.
Just finished making a dinosaur, which worked perfectly in DS, but did some really strange things in C 8.1, so ran some tests on a simple figure.
The cr2 works perfectly in DS, but in C, whether using Tri-Ax or parametric, in most cases, but not all, it reads the bones hierarchy wrong; for instance, the weights for r-leg is allocated to r_thigh - always one up in the hierarchy and the child bones are not attached. In other cases, such as the shoulders, it reads and behaves correctly.
I'm just wondering whether this works OK in C8.5 and Daz has just made 8.1 redundant for this purpose?
  • fabafaba Posts: 53
    edited April 2014
    Hello Roy,
    I never had comparable issues when rigging in DAZ Studio for Carrara.
    Can you upload the project files to have a closer look at?
    Post edited by faba on
  • RoygeeRoygee Posts: 2,247
    edited April 2014
    Hi faba - thanks for offering to take a look :)
    Here is the link http://www.4shared.com/folder/8zr8R9Ok/Myfigs.html
    Post edited by Roygee on
    Looks like 4shared doesn't work very well for me.
    Would you mind to upload the file somewhere else?
    In case you would like send it as e-mail check your PMs.
    I've sent it to you by e-mail. These upload sites can be confusing - I've just now learned how to get a link from Dropbox - the instructions say to hover the mouse over the file, but you have to actually r-click to get the link :)
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,576
    have you tried the triax .duf in carrara 8.5
    weight painted Cr2 for Poser 9+ maybe Fenrics script in Poser could fix
    save as support asset figure character .duf import that into carrara
    Hello Roy,
    When I open the file in DAZ Studio and watch the weight assignments I can see that lines that show the static/ posed angle are flipped (red is static, green is posed).
    I attach a screenshot
    When i fix the angles (red to static/ green to posed) it behaves in Carrara as expected.
    689 x 539 - 85K
    That is great - thanks:)
    What tool do you activate to see the weight assignments and angles? That is what I used to see on the old DS3 FST, before they introduced weight-painting. Never seen them in DS4 and thought that those and the sphere influences had been replaced by weight-painting.
    @Wendy - I'm on C8.1, so DUF is not for such as us:)
    those options are still there if you are editing a parametric character.
    818 x 982 - 106K
    Aaah, yes, I see it now - I'll know what to do if this problem comes up again :)
  • DartanbeckDartanbeck Posts: 21,988
    Very cool... thanks for this!
