• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Poses
Those ThingsThose Things Posts: 1,146
August 2020 in Blender Discussion
Is there currently any way to port poses from Daz to Blender? Asking for a friend...
  • PadonePadone Posts: 4,023
    August 2020
    Diffeomorphic can import poses and animations. Doesn't work with aniblocks you have to bake them to the timeline first. Use the mhx rig or no rig at all for better compatibility, avoid rigify.
    https://diffeomorphic.blogspot.com/p/daz-importer-version-15.html
  • Krys KryngleKrys Kryngle Posts: 313
    August 2020
    Yes, both Diffeomorphic and the new DazToBlender can import poses.  Diffeo is very easy and can save pose libraries.  The new plug-in works with the #get pose command, but I had some issues where it would import some poses but not others.  Maybe I was doing something wrong.
    August 2020 edited August 2020
    @Krampus The #get pose command seems not officially supported by daz and as you discovered yourself it doesn't work fine anyway.
    https://helpdaz.zendesk.com/hc/en-us/articles/360046244152-FAQs-for-Blender-Bridge
    Poses will not successfully transfer to Blender.
    Post edited by Padone on August 2020
  • nicsttnicstt Posts: 11,715
    August 2020
    And once you have a library in Blender, you can append it to another diffoe character.
  • Those ThingsThose Things Posts: 1,146
    August 2020
    Good to know, thank you. I hope the ability to port poses over to Blender is a future improvement.
  • Archangel FirewolfArchangel Firewolf Posts: 9
    I managed to export poses by turning the pose into a pose control.
    Step 1
    Apply pose to Genesis 3/Genesis 8
    Step 2
    1.Go under Parameter Settings/Pose Controls
    2. Right-click in the slider area - select "Edit Mode"
    3. Right-click again, then select "Create New Property"
    4. Give the new property a name. You can put anything in the name section - I didn't have to fill anything else in. Then hit "Create" at the bottum.
    5. Right-click on the Property (slider) that you created and select "ERC Freeze"
    6. Once the "ERC Freeze Options" menu comes up - hit "Accept" and the pose is now a pose control. The new slider should go to 100% and work like a pose control.
    7. Use Daz3d to Blender export. The pose should export and then import into Blender.
    I don't have Pose Architect, but I would guess that any pose created with it would export, provided that you use only sliders to create a pose and not use the "bake to transforms" script.
    Post edited by Archangel Firewolf on August 2020
    August 2020
    Step 1
    Step 2
    Ooooh, thank you. Going to try this today!
  • frank_f6ded5dcfrank_f6ded5dc Posts: 0
    August 2020
    Cool!  This worked for me - thanks
    but I ran into one issue- once I imported the Daz figure (and it held the pose YAY!) I wasn't able to move the figure at all - like i couldnt rotate it or move it from where it imported into the scene.
    What am I doing wrong?
    In Blender, pressing R on the keyboard will allow you to rotate. You can use the shortcut "Shift + Space" to bring up more options in the Transform menu. The menu will show Grab(G), Rotate(R), Scale(S), etc. The transform tool is similar to the universal pose tool in Daz.
    800 x 432 - 171K
    Please note that this way jcms will not work anymore in the exported figure, that means you lose deformations. So this workaround is only good to import static meshes.
    240 x 260 - 13K
  • SoulMystSoulMyst Posts: 10
    August 2020
    Step 1
    Step 2
    This actually works!!! Thanks for the tip. Being still new to Daz it's great to use the new export script. I used diffeomorphic and experimented for a day but there are differences and also strengths to each.
    Only only thing I still need is to find a way to export a baked timeline animation... diffeomorphic just will not retarget any .bvh to a daz model :( tried for 2 days now.
    Is there other ways to get animations like a walking into blender apart from trying to attach a .bvh file? Am I missing something in Daz export or is there another way in diffeomorphic or daztoblender script?
    August 2020
    http://diffeomorphic.blogspot.com/p/bvh-retargeter.html
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
