Problems with Genesis 2 Female to Genesis Autofit Clone
dakkuuan
Hi guys, having some issues with my recently acquired Genesis 2 Female to Genesis Autofit clone... I get this second autofit window when I try to fit something and then it typically doesn't work. Any ideas?
EDIT: If I don't pick a second item (the clothing type) it works...sort...but it fits very loosely and it's very obvious.
Post edited by dakkuuan on
Is this the item that you bought : http://www.daz3d.com/genesis-2-female-clone-for-genesis
If so, the Product Page says that there is a manual supplied with it, have you found it?
Yeah thanks for the suggestion. I read through the manual and tried the transfer utility method and got the same result. No other useful info could be found. I also tried the 'Genesis 2 Female Tight Fitting Pants' clone and that didn't change anything either.
Sickleyield usually responds on these forums, but you could try dropping her a pm?
I'm afraid I don't have this set, maybe someone else can help more
Interestingly enough, the first problem cleared up, I can use the presets now. Some items still fit very far off the body, especially something with straps like the genesis 2 female basic top and you can see right through her bottom to below her from the pic I posted. I'll drop her a pm and see what she says. I have a feeling genesis changed since she released the clone, since it has been updated numerous times.
Very strange, I hope you get to the bottom of it.
Thanks for letting me know.
