• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > 3ds Max Discussion
Temp file
whitesentinix6355962whitesentinix6355962 Posts: 142
July 2020 in 3ds Max Discussion
So I was able to successfully install all four bridges and then ran into a new problem.  When I use the bridge in DAZ, the information is being sent to a temp file SOMEWHERE on my computer.  I go into 3DS max and try to bring it in via DAZtoMax, but 3DS is pulling from a different file.  How can you trace which folder the information from Daz is going, where Max is pulling it and how can you re-direct so the bridge is finally speaking between the different programs?
  • Richard HaseltineRichard Haseltine Posts: 109,533
    July 2020
    Check the folder listed in Edit>Preferences (Daz Studio>Preferences for a Mac).
  • whitesentinix6355962whitesentinix6355962 Posts: 142
    July 2020 edited July 2020
    Oooh!  How about on the 3DS Max side?
    Post edited by whitesentinix6355962 on July 2020
    July 2020
    I'm not familiar with 3D Studio Max (or Cinema 4D, about which you are asking the same question).
  • carbunclemaxcarbunclemax Posts: 88
    Hi adman_gragg,
    the script history which is more easily viewed in the system log says that the file is exported as fbx to C:\TEMP3D\DazToC4D.fbx
    Just open from there in Cinema4D and save as a cinema4D file as you like. I suppose it would be good if it opned cinema4D but there are benefits in this method too.
    Hope that helps.
    PS. First time I tried the bridge and it seems to work hunky dorey and better than the old FBX export. I will play round with figure later and see how it pans out.
    Post edited by carbunclemax on July 2020
  • alan bard newcomeralan bard newcomer Posts: 2,383
    July 2020
    3dMax has import / export folders .. where it looks first
    I have enough going back betweed 3dm and daz (objects) that I just have a top level folder on the daz drive labeled 3dmax and save to there and look in there
  • voodoofuzzvoodoofuzz Posts: 10
    July 2020
    So it uses maxscript and FBX format I gather?
    Max 2021 now supports Python, hopefully one could automate teh whole process.
    For years now I've been doing the whole process manually - this has greast potential maybe.
    July 2020
    There is also a script within Cinema4D which will open the file automatically without having to go to the temporary folder to locate file and import as an FBX. I lean't about this when I reinstalled Central and my previous problems seemed to have been ironed out there as well.
    August 2020
    Good to know!
  • waldowaldo Posts: 3
    September 2020
    The FBX file is being placed in your root drive in the folder TEMP3D on my system that's C:\TEMP3D
    After export from DAZ you will have a file DazToMax.fbx and DazToMax.xml
    wd
    675 x 201 - 22K
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
