More problems with models
anthscoanthsco Posts: 19
The Daz Blackhawk is an excellent model but every time I load it and open up doors this happens and this also happens with two other models. What is going on here?
    Looks like a problem some other models have had. They required updating to the newer programs which apparently handle groups a little differently. Not all .cr2s were created using the very same methods. Might be a good idea to shoot a note [politely] to CS.
  • anthscoanthsco Posts: 19
    Good advice but who is CS?
    edited April 2014
    Customer Services
    Contact them by using the Contact Us button and filling in a help request.
    I would think probably Tech Support would be the best dept.
    Post edited by Chohole on
  • frank0314frank0314 Posts: 14,765
    Are you using DAZ Studio or Poser.
    Daz 4.6 64bit. I dont have Poser.
  • Richard HaseltineRichard Haseltine Posts: 109,164
    This sort of thing happens when the model is made with parts not fully separated - if you need it before it can be fixed at DAZ you can do so in many modellers by selecting the door or whatever, cutting, and pasting back in place - just check that the UVs aren't destroyed first, which will depend on the modelling application used.
    Okay let me see if i understand...i cant fix it in Daz but I can fix it in another modeling program?
    Yes.
    I will give it a try in Carrera or 3DSMAX. Thanks for the help.
    I have also contacted CS as advised.
