Prop hunt: wood shavings
JOdel
in The Commons
Such as would be used as bedding in a pet cage, so would need to be a mat of then, rather than single ones. Anyone know of any, or something that could fake it with a shader (3DL).
CC Shave This - Thicker
I know you said 3DL, but this shader kit has both shavings and chips - https://www.daz3d.com/iray-woodworx-shaders
That is an interesting shader. Just for fun I applied the image to the morphing terrain in Maclean's "Everyday Morphing Primitives" set. The morphing terrain is a sort of blank sheet that can be bent and roughened.
It is also very easy to "extrude" or "sweep" out various surfaces in Hexagon into objects that at least vaguely resemble wood shavings - similar to the shapes shown above. Throw a few of these in, colored various shades of light brown and you may just come up with something.
