Prop hunt: wood shavings
JOdelJOdel Posts: 6,322
Such as would be used as bedding in a pet cage, so would need to be a mat of then, rather than single ones. Anyone know of any, or something that could fake it with a shader (3DL).
  • MarcCCTxMarcCCTx Posts: 947
    CC Shave This - Thicker
    600 x 600 - 92K
    I know you said 3DL, but this shader kit has both shavings and chips - https://www.daz3d.com/iray-woodworx-shaders
    1678 x 1619 - 668K
  • Roman_K2Roman_K2 Posts: 1,277
    edited July 2020
    That is an interesting shader. Just for fun I applied the image to the morphing terrain in Maclean's "Everyday Morphing Primitives" set. The morphing terrain is a sort of blank sheet that can be bent and roughened.
    It is also very easy to "extrude" or "sweep" out various surfaces in Hexagon into objects that at least vaguely resemble wood shavings - similar to the shapes shown above. Throw a few of these in, colored various shades of light brown and you may just come up with something.
    1411 x 625 - 254K
    1350 x 637 - 216K
    1341 x 844 - 153K
    Post edited by Roman_K2 on
