Movement of Waving Flag Not Rendering
What do I have set wrong to cause the movement of my waving flag not to render in Carrara 8.5 Pro?
One frame is rendering only.
What info should I share to help diagnose this problem?
Thanks in advance for any help provided.
In the Render room, go to the second tab (panels on the right) "Output"
Change the setting from "Current Frame" to Video and set how you'd like to output the frames.
I have a short article on Rendering Outputs in my "Pacing and Rendering" article: (this link scrolls down to the relevant info)
https://www.dartanbeck.com/carrara-zone/carrara-cg-workshop/pacing-and-rendering#h.p_styt3hVaZw4P
With a physics simulation, be sure that you have the timeline start and end markers set to the area on the timeline that you've simulated, be sure that you've run the simulation ("Simulate Physics" button - the top left button)
afaik mov is only on the mac version
Can't find it in the manual but the 'Animate' button in the top left of the sequencer is like an 'auto key' button. If it is turned off you can make any changes you want in the scene anywhere on the timeline and Carrara won't create a keyframe. When turned on, Carrara creates a keyframe for anything you change down the timeline (unless it's a feature that can't be animated, which is rare in Carrara).
I'm on a Mac so can't help with AVI advice, sorry. I've read off an on here that others have had mixed luck using AVI. Have you tried rendering the animation to an image sequence yet? You can import the image sequence into an external video editor and export to any format available in the the video editor. There are many free options out there.
Sorry if that's 'broken record' advice.
i've never had any trouble with uncompressed avi. win7 snd win10. i set a big scratch disk. 80gb of free space
i let the win10 video editor convert it to mp4
the animated gifg works well too. i set it to 89, diffused
Is it rendering 'frame 0' no matter where you move the time bar / playhead?
I was digging a little deeper 'cause I feel like I have seen this problem described before and found a possible solution: maybe try setting Smoothing to '0' in the Soft Body Modifier.
You can simulate with a higher smoothing number, but when it comes to render time for animation, set it to zero, apparaently there is a bug? I don't know because it worked from my end with smoothing set higher, but I'm on a Mac, maybe it was a Windows bug?
Might be worth a try.
Setting the Smoothing to 0 did the trick. Thanks for that tip!
First Steps Physics by 3dage, here under Publication > https://carraracafe.com/downloads/
Yaaaay!!!
Also, although I have now switched entirely to rendering to Image Sequence, and use DJV to view the sequence when the render is done (or before if I want to se how it is 'so far') I've rendered to Full Frames avi for years and years - then I'd use those full frames files in Vegas to merge all of my clips together, and finally add a codec for the final version.
Codec - This is a Huge topic. There's a Lot to understand about codecs. I don't know any of it, so I let Vegas, VideoStudio Pro or DaVinci Resolve help me figure out what I want.
DJV - Awesome! Just drag one of the image file from a sequence into the window and it'll let us play the sequence back at a variety of common speeds. Seems lightweight to me, but this is the most powerful machine I've ever used, so everything seems kinda light! LOL
All that said, I'm so glad that you were able to get it rendered! DesertDude, You ROCK!!!
Very Cool rk66! Thanks!!!
Cool, glad it worked!
Thanks Dartanbeck, but 'tip of the hat' really goes to FENgari, and later in the thread confirmed by WendyLuvsCatz:
https://www.daz3d.com/forums/discussion/comment/4604776/#Comment_4604776
"I've been having this particular problem recently and found that by setting the SoftBody 'Smoothing' parameter to 0 clears the fault and the cloth will animate and render as expected using the Photorealistic render. I completed a quick experiment involving a cloth simulation with Smoothing set to 1, tried to render - no go, then reduced this setting to 0 and it rendered??? I haven't tried the reverse; ie complete a simulation with 0 as the setting and then trying to render with it set on a higher value... I just thought I'd share that with you."
Sweet! Thanks again! And Thanks FENgari and WendyLuvsCatz!!!
I barely remembered it
That's because you're Always pushing open new doors of creative work-arounds to make stuff work!!!
I couldn't have gotten this done without this Forum. Really appreciate this knowledge base!
My render of the flag looks pretty good except for the banding in the white color into the graying shaded areas. What is the right render setting to reduce/eliminate that?
Thanks again for everyone's help.
Can you provide a still or a screen grab of the problem? I'm can't quite picture what you are describing
Attached are two different images rendered with different settings. The PNG without the tree background was rendered with higher global illumination settings resulting in a crosshatch banding which seems to have more detail so maybe I need to cranking those settings up a lot higher.
Thanks for you input.
