Removing add-ins
How do you remove add-ins you no longer need? Searched the forums with no luck, and the menu Windows don't lead to anything that removes them.
This
If you installed them with DIM, you can uninstall them with DIM.
Doesn't work. I've tried that and both items I'm trying to get rid of show as 'disabled'. But they both try and load on start-up.
I'll have to try that. I don't think the one was installed via DIM; not certain with the other.
What do you mean when you say they try to load on start up?
Get the registration window for Garabaldi. When I cancel, it then shows file window to find Reality. I close that window and then DAZ finishes starting.
How did you install them?
That's a great question. Got a time machine? No recall at all how they were installed.
Do you use DIM or standalone installers?
It's been a while. No clue as to install type or date. Since at least 4.9 to my best recollection. It shouldn't be this hard.
Do you have DIM?
Yes and neither item shows up in DIM.
In Installed or in Ready to Download?
Do you know where you purchased them?
Have you tried just deleting the associated DLL files? I mean there's not a lot else to plug-ins.
