Removing add-ins
How do you remove add-ins you no longer need?  Searched the forums with no luck, and the menu Windows don't lead to anything that removes them.
    This
  • barbultbarbult Posts: 26,714
    If you installed them with DIM, you can uninstall them with DIM.
  • sberlinssberlins Posts: 128
    fred9803 said:
    This
    Doesn't work.  I've tried that and both items I'm trying to get rid of show as 'disabled'.  But they both try and load on start-up.
    I'll have to try that.  I don't think the one was installed via DIM; not certain with the other.
  • Richard HaseltineRichard Haseltine Posts: 109,828
    What do you mean when you say they try to load on start up?
    Get the registration window for Garabaldi.  When I cancel, it then shows file window to find Reality.  I close that window and then DAZ finishes starting.
  • fixmypcmikefixmypcmike Posts: 19,711
    How did you install them?
    That's a great question.  Got a time machine?  No recall at all how they were installed.
    Do you use DIM or standalone installers?
    It's been a while.  No clue as to install type or date.  Since at least 4.9 to my best recollection.  It shouldn't be this hard.
    982 x 1214 - 94K
    Do you have DIM?
    Do you have DIM?
    Yes and neither item shows up in DIM.
    sberlins said:
    Do you have DIM?
    In Installed or in Ready to Download?
    Do you know where you purchased them?
  • SevrinSevrin Posts: 6,314
    Have you tried just deleting the associated DLL files?  I mean there's not a lot else to plug-ins.
