hi does anyone know where i can find a spring prop for daz studio
lasagnaman
in The Commons
like this
I know how to make one in Carrara, just toss a spline spiral in
not sure but I think Hexagon has a spiral too
yes helix under lines, I don't really know how to model in Hexagon though but it's free
ty so much wendy ill try that
You could kitbash this free one.
https://sharecg.com/v/74392/browse/11/Poser/Heartz-Spring-Prop
Everyday Morphing Primitives has some springs. There's a tapered morph, too.
This could be done in Blender with a Screw modifier and a Simple Deform modifier set to Bend. You could also add a driver to stretch and compress it as needed.
yeah thats what i thought blender but i couldnt figure it out do you have a tutorial by any chance
You can get a spiral spring that isn't conical using just a Screw modifier, and adding a Simple Deform modifier using the Taper option will indeed taper the spring as a whole, but it will also distort the profile of the 'wire' itself as well (see attached, grey object - at the right hand end, it has become oval). You can avoid this as follows.
Getting the bit of compression at each end is another exercise!
Convert to a mesh e.g. if you are going to export it from Blender.
ty so much andya ty ver much for this
