Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Yeah, hopefully people see that even though there's a few issues here, everybody who's commented here has actually still recommended it even despite small annoyances.
In actuality, it's pretty high praise to still deem the character "worth it"... hopefully anybody feeling burnt or that the product is broken beyond repair checks here first before jumping to conclusions.
All of the renders so far have been stunning
She has to be one of the most incredibly realistic, unique and beautiful morphs I've ever seen for G8!
Decision made: I have to buy her and support this artist! They might not have all of the technical stuff packaged and loading up correctly this first time but they're innate artistic talent is so obvious! I don't want them giving up :)
I am hoping the artist will post some fixes, maybe even if with help from an established PA to get them started - I would LOVE to see more characters from Carboncrow! I had the same puffiness in both character loading and G8F base loading then adding the morph. Followed advise here and got it sorted out. I like this character A LOT! Here's a quick render using Hagar, LUXE eye brows, BOSS Lighting system, Shavonne Hair (EJ for G3F converted with a hair converter) and hair color by Chevybabe. WHEW! I think she is worth a little effort (even if I prefer NOT to have ot fiddle with a purchased product - this was worth it! Keep going Carboncrow!)
Some nice renders, and can't say I'm thrilled about the issues folks are having but I probably wouldn't have noticed as I start off by tweaking a lot, and then just continue from there.
Can't say I'm a fan of seeing the diffuse textures are a merchant resource, but the normals are excellent and Tiff files too. They look really good, which explains the detail in the promos, well that and that the displacements are .Exr files - that way they have sufficient information to displace correctly, which doesn't explain why im seeing the same issues as has been reported.
Turning displacement down low enough to remove the effect appears to make no difference.
I've raised a ticket; will see what happens.
You would have noticed as soon as you saw the Iray preview. Can't tweak what you can't see.
Holy Mackrel! What's up with the muffin woman during Iray Preview with this model? Was there a QA check before hitting the store?
The more you test, the more bugs there will be.
I render in Blender, and have my own custom materials set up; didn't see any issues there in a quick test with just the displacement, but did as I tried in Iray after seeing what other's had posted.
I havent had any problems with the displacement in preview or render. I did run into the issue of the eyebrows not parenting though.
How did you fix the problem?
I restarted my computer, booted up DAZ, loaded Hagar and without doing anything to it, I started a render and this is what I got (see attachment on left). Attachment on right shows what it looks like in the editor. Is anyone else having these difficulties?
I was really looking forward to this character but presently I am less than happy with it.
Mod Edit:- Image removed due to nudity
I deleted the displacement maps wherever I found them.
What tab do I find these displacement maps?
Surfaces tab. In the Geometry section.
thank you
I reduced her texture size for this.
Did some tweeking & tuning & borrowing from other packages and this is what I got.
Drogo...
Tweaking? ha... that is a bit beyond tweeking!
Very interesting results though... cheers!
Hi guys,
I think I might have found a couple of easy fixes for the problems people are having with Hagar that you could maybe try for yourselves.
From a bit of experimentation it appears to me that the displacement setting should only be for the torso and somehow got applied to the entire figure so if you select (in surfaces) Arms, Ears, Face, Legs and Lips (DO NOT SELECT TORSO) and change the Displacement Strength to 1, the Minimum Displacement to -0.1 and the Maximum Displacement to 0.1 then Hagar should look a lot less like she's in the midst of an Iray allergic reaction. Now even with this you may still see some very faint lines where the UVs meet which makes me think think that the actual values will be a bit more tweaked than what I found but hopefully that will come through with any official update and this will do for a 'good enough' temporary fix.
As for the eyebrows the fix is even simpler. When everything is loaded up select Hagar Eyebrows in Scene, left click on it and instead of fitting them just change the parent of the eyebrows to her head. Then the eyebrows will stay in the correct place with any pose without distorting.
Hope this helps someone because Hagar is a lovely character and, in my opinion at least, well worth buying.
Cheers all,
Stu
I guess that figure would totally win a Keith Richards Lookalike Contest
when I read this title was thinking you were talking about Hagar The Horrible loved that comic oh and she ain't horrible looks pretty
I have to leave and the render is slow (Mac so DS doesn't use its GPU), but Arms, Ears, Face, Legs, Lipsm and Torso with a Displacement Strength of 0.92 the Minimum Displacement to -0.1 and the Maximum Displacement to 0.1 seem to get rid of the UV intersection lines. Hopefully we'll see an update soon, Carboncrow has done excellent work.
I don't think he has hips like that
Hello folks! First of all, I would like to say thank you for everyone who supported my work. I am sorry to hear that many of you had a problem with the product. I listened the complaints and investigated the matter. The problem with the displacement map seems to be caused by that different versions of Daz handling the displacement maps differently. That's why some people have not experienced any issue at all (except the problem with the eyebrows). I'm working on a fix that makes the displacement map optional, so if you use a different program version, the product will still work properly. The update will also include an eyebrow fix. Anyway, I would recommend that anyone who has a problem with Hagar try to updating to the latest version of Daz Studio Pro. This may solve the problem of the displacement. Please let me know if you experience any other problems.
It's not a matter of old versions. I'm using 4.12.1.117. You should test with the version of Hagar available for download.
Thank you. Since you advised that a fix is in progress, I'll go ahead and buy her. Very nice looking model! Hope to see more from you :)
thank you for your response.
I'm not using the latest. Doing test renders in it, I get a different look on characters I've created. Not as important now I render in Blender, but still an issue.
I'll see what happens when I upgrade; I keep lots of backups so it's not a problem.
Nice looking character, shame what happens when you render her. Haven't noticed a problem with the eyelashes yet.
Are Daz actually doing any QA these days ?
Hope whatever the problem is gets fixed soon, I've opened a support ticket which I expect they will get to eventually.
Steve.
Ahh the same thing happens when you apply the character to G8F, I thought it was just the character preset that was broken
In response to the vendors comment I am using the latest release version of Daz Studio 4.12.1.118.
Later...
Turned off displacement maps, appears to render OK now. Really nice for a first character, shame the release was messed up, hope you have better luck with the next one, we need vendors that can do something other that the constant stream of barbie dolls.
I plan to purchase her absolutely. I'm a big fan of characters that have attributes unlike many of the characters you'd normally see in the store (Alfan's fatal stranger, Queen of Desire which I have) and older looking figures.
I like the look of Hagar to me the promo images make her appear as a slightly older female in the early 40's to 50's. I look forward to using her.
I have questions has anyone used clothing and footwear on her? If so how do they look on her frame? Looking at her feet l fear there maybe an issue with footwear like heels, etc.
Just chiming in...
I have the latest public daz release, and still have the displacement issue (though solved it with Stuthurso's fix. Oddly, I couldn't solve my eyebrow issue with just parenting it to the head... so I just deleted them and put others on.
All in all, I gotta say I REALLY like this character.
Cheers to the PA... can't wait to see more of their work!
