REWARDS FOR THIS CARD WILL BE ISSUED ON - SUN. APR 6
CybersoxCybersox Posts: 9,770
So, er... WHEN on Sun. April 6th?
    Try refreshing the page and you will see that it actually says REWARDS FOR THIS CARD WILL BE ISSUED ON - MON. APR 7
  • CybersoxCybersox Posts: 9,770
    Nope. Tried reloading, logging out/in, etc. I even shut down firefox and brought up the page again in IE. It still says Sun, April 6th.
    And needless to say, none of that changes the fact that it said that when I purchased the last item I got a punch for.
  • frank0314frank0314 Posts: 15,048
    Did you try clearing your cache. Its showing the 7th and the punches are working now
    It eventually switched over, but I already had the correct punches. That said, the question is: why did it ever go up reading Sun, April 6th to begin with? That's not a cache problem, that's the wrong date being advertised in the first place.
  • KhoryKhory Posts: 3,854
    That said, the question is: why did it ever go up reading Sun, April 6th to begin with? That’s not a cache problem, that’s the wrong date being advertised in the first place.
    Because DAZ is made up of humans beings and humans are not perfect and can make typing errors and not catch them right away.
