can i save a prop with lights attached to it to library?
Mistara
something like a vanity mirror with lil point lights around the edge.
can i save the prop with the point lights?
or if i have to, make the prop into a figure, can i save the figure with the lights attached to the library?
Thanks!
Save it as a Scene subset, or even a Scene. You can put it anywhere inside your My DAZ 3D Library. DS Formats has a Prop folder already I believe.
I believe both ways can work. After all a Sky Dome with lights is only a Prop in the content folder. You should Parent the lights to the Prop and save the item as a prop then. I think that should work.
