I forgot ... ?
Is there anyway to figure out what skin I used on a character?
  • fixmypcmikefixmypcmike Posts: 19,718
    See what the name of the .jpg is and hope it's distinctive enough?
    What Fixmypcmike means is to select the torso with the Surface Selcion Tool and have a squiz at the texture by going right click/browse to see where it it is. 99% of the texture names will show what character they belong to. Not rocket science.
  • Drogo NazhurDrogo Nazhur Posts: 1,322
    could you explain that? Right clicking what? The skin?
    Select the surface, then go to the Surfaces pane and click on the little box to the left of the slider (Diffuse Strength for 3DL, not sure what it would be for Iray) and choose browse, and it should open up the folder with the textures.
  • JOdelJOdel Posts: 6,322
    Just select a surface and look in the surfaces tab. That will give you ne name of the linked file.  (Or at any rate that's an easy way to check in 3DL. I'm sure there's a place in the Iray array which names the linked files as well.)
  • duckbombduckbomb Posts: 585
    You can look at the map in the "base color" field for Iray...
  • SevrinSevrin Posts: 6,314
    edited July 2020
    It's here.
    485 x 603 - 62K
    Post edited by Sevrin on
    Thank you one and all. It worked. This little trick opens up a world of possibilities
