JeffersonAF's The Park Way
Bought this on a whim, and I'm impressed. Self-contained, thoughtful presets, apparently very efficiently modeled:  I haven't had a render yet take more than 1500 samples to run to completion. This test render (no post) took under 1300 samples for default render goals.
Very nice work imo, JeffersonAF!
  • TimbalesTimbales Posts: 2,456
    I grabbed it, too. It was a great deal and thought I could, at the very least, use the individual components. Glad to see it renders nicely.
  • LoonyLoony Posts: 1,817
    edited July 2020
    One Problem I have is, it have every prop duplicated and now I learned with instances can you save a lot Ressources Power.
    I made the work to replace all "big" props with instances (I just ignored the grass, cuz 1 grass prop have just 100 polygons), I reduced the Scene from 1.1Million Polygons/Faces to just 200.000.
    @Richard Haseltine
    Can I upload the scene subset with the instances somewhere and share it here or is that not legal? Would it still require the Product to get loaded or does it work without?
    I spent 30-50minutes to adjust all and I would like to share this here, so others can use it.
    Post edited by Loony on
