Skin Overlay - Now Available (commercial)
124»
  • Zev0Zev0 Posts: 7,122
    edited April 2014
    Did you click apply settings after you changed it? Too be honest the texture resource settings is the only reason I can think of as to why it is laggy. And ignore the viewport results, it will look bad unrendered because its showing a low quality preview to optimize performance.
    Post edited by Zev0 on
  • marblemarble Posts: 7,500
    Yes I did click apply - I saw the texture quality change as I explained (bucket of mud). Sorry.
    Ok close daz and open it again just to refresh everything and try again.
    edited April 2014
    This is my settings. Try changing your display optimization settings.
    423 x 734 - 60K
    As I said - this is a Mac - the settings are different. I don't have all the options that you do.
    As you suggested, I have restarted DS and it made no difference at all. Still painfully slow. Please could you respond to the question I asked about using Photoshop/Gimp? Thanks.
    edited April 2014
    Well sorry to hear. I did however see display optimization settings in your post of your settings. So even if its a mac it has that setting.
    If you know how to use photoshop\gimp, then yes you can manually apply the layers yourself. Just have a look at the texture folder of the product. Should be easy to understand. Most of them are png's so they can easily overlay on the texture. Most use the multiply blend methods so set the layer to that and just adjust the opacity to your liking.
  • barbultbarbult Posts: 26,294
    Here is a thread about LIE and tdlmake causing slowness and other troubles. If this is what is happening to you, you would be the first MAC user to report that it is affecting you. That might be important information in figuring this out, because people have been suspecting Windows update problems as the cause.
    I was just about to mention the same thing. Strange if it is happening on macs as well.
    Zev0 said:
    Well sorry to hear. If you know how to use photoshop\gimp, then yes you can manually apply the layers yourself. Just have a look at the texture folder of the product. Should be easy to understand. Most of them are png's so they can easily overlay on the texture. Most use the multiply blend methods so set the layer to that and just adjust the opacity to your liking.
    Thanks, I'm just about to attempt that now. I understand multiply and layers so I should be OK.
    As a matter of interest, what is different about using there overlays and using the ones in your Merchant Resource? It's ok if that's a trade secret ;)
    Lastly, can someone remind me how to create a new icon in the Content tab for any new texture modification I create?
    edited April 2014
    The MR grants you the license to use the overlays in a selling product eg, can be used on a product you wish to sell. It is also set up differently and contains extra layers. The normal version is a preset of those layers.
    Zev0 said:
    The MR grants you the license to use the overlays in a selling product eg, can be used on a product you wish to sell. You cannot use the standalone version for that.
    Ok - I see. Not a problem as I don't intend to sell. This is strictly a hobby.
    Thanks.
