Hair - Fur - How do I?
StezzaStezza Posts: 8,802
I have an item of clothing and I have made a transmap for it to give it a jagged look.. see the images
I want to add fur to the clothing which is an easy part, but how do I apply the fur to only the part that is visible and not the transmapped parts?
I can't find anywhere to add a map for the clothing fur....
thanks anyone
  • DiomedeDiomede Posts: 15,393
    Couple of options might work
    in the hair domains tool, use select by
    1) you can create a shading domain where you want the fur
    2) you can load a texture map (uv based) for the distribution of fur
    3) you can use the green paint tool to paint where you want the fur
    Holly has a fur tutorial if we can track it down. My guess would be that it is at carraracafe.
    486 x 409 - 42K
    On second thought, you are probably going to do what you want to do in the hair shader room. Use a similar texture map for the density in the shader that matches your alpha setting.
    277 x 395 - 33K
  • StezzaStezza Posts: 8,802
    Thanks diomede64,
    that option solved my problem... :-)
  • DartanbeckDartanbeck Posts: 21,984
    Just in case, here's Holly's Web Space
    Great articles and tutorials!
    Can we see the fur shirt when you're done?
    yep.. here is the link
    http://www.daz3d.com/forums/viewreply/580458/
    It was for my entry in the
    Custom Character Contest 2014 - Best Likeness
  • SileneUKSileneUK Posts: 1,977
    Stezza, I never thought to use transmap to make jagged edges.... will have to try that as it will be useful for me!! Thanks!
    Holly, I need to visit your site as you have so much information that is easy to understand. Whether or not I can execute it is another matter, but will keep trying to add to my learning curve. Thank you!
    xx :) SileneUK
    Awesome Fred you've made, Stezza!
    edited April 2014
    xx :) SileneUK
    that's great Silene... we both learned something yay
    @dart..
    thanks mate... took a few goes to get it the way I liked.. lol.. yabadabadoo!
    and all done in Carrara ;-)
    Post edited by Stezza on
