Pose Fusion for Genesis to Genesis 8 (Commercial)
124
  • Richard HaseltineRichard Haseltine Posts: 111,438
    dynamo3d said:
    Question:
    Can´t load the script. Logfile says:
    2020-07-07 22:22:09.860 Loading script: D:/DAZ/Connect Content/data/cloud/1_68845/scripts/pose fusion/pose fusion.dse
    2020-07-07 22:22:09.860 Failed to load script: D:/DAZ/Connect Content/data/cloud/1_68845/scripts/pose fusion/pose fusion.dse
    I try other scripts - load normaly.
    Update Metadata helps not.
    Uninstall and re-install even not helps.
    Using DAZ Studio 4.10 Pro
    So any suggestions what to try best next?
    Uninstall the Connect version and install using Install Manager or Daz Central, the script appears not to be written to work with Connect.
  • marblemarble Posts: 7,500
    Just bought this to add to my Zev0 collection. Having tried it I notice that the adjustment sliders within the tool panel are very sluggish compared to the same adjustments in the parameters pane (Bend, side to side, etc.). Any idea why or am I missing some trick?
  • Zev0Zev0 Posts: 7,123
    It's as fast as we could get it. We will see what we can do to get it a little less sluggish. Will have to compare with other scripts that have such a feature to see if it's the standard script emulation speed or something specific inside PF causing it.
    Thanks - I hope you can find the cause. I'm no programmer but I would have thought that the adjustments would use the same functions as the parameter sliders? Anyhow I'm thinking this could be a very useful addition to the toolbox.
    edited July 2020
    Ok we found the bend slider in the script works faster than the native parameters, the side by side and twist is a bit slower framerate wise. This is due to items being smoothed everytime as adjustment is made. We also compared to other scripts and the result is the same, so this is just how scripts deal with internal sliders. Only solution is to disable smoothing while the script is open, but then you will be looking at pokethrough on items. When figure has no items loaded it is the same.
    Post edited by Zev0 on
  • dynamo3ddynamo3d Posts: 5
    dynamo3d said:
    Question:
    Thanks - install with Daz Central also not solve my problem but it´s ok :)
  • GreybroGreybro Posts: 2,706
    Nice tool set. One question/ constructive critic. So, when I create a new pose from fusing two others everything works as expected. On "save" it also saves the expression data. I was surprised by this as the Daz requirement for poses doesn't allow for expression data to be included and in my case I was hoping to save time in saving by not having to drill down to the head and uncheck everything but general. Could that possible be adressed in an update? I realize that my comments are very PA-centric but hopefully I've made some sort of sense with it.
    edited July 2020
    Hi. That is why we included a clear expression button if your pose used contained one. Just click that before saving. We didn't force this because there are other sites that allow poses to be saved with expressions and some people would want them saved out that way.
    583 x 883 - 67K
  • Nick_1939Nick_1939 Posts: 37
    inquire said:
    Hi: I just bought the product yesterday. I'm on a Macintosh, running OS 10.12.6, Sierra. Thought you should know that. OK, this morning I decided to test the product out. I went to Scripts and clicked on Pose Fusion. I got an error message. I'll attach a Screen Shot. I tried several times, clicking on a character or on a character part, such as "Lower Abdomen." Of course, the error message says to check the Log File, so I'll include the relevant part of the Log File, which just basically says that DS failed to load the script.
    Beyond this, I don't know what to do. Hope this will run on a Macintosh. Below, part of the Log File:
    2020-04-25 11:46:44.172 Saved image: /Users/s/Desktop/Latest Poser n DAZ Studio Files/Min Joon and Roy_TEST for POSER FUSION.duf.png
    2020-04-25 11:47:05.548 Loading script: /Users/Shared/My DAZ 3D Library/Scripts/Pose Fusion/Pose Fusion.dse
    2020-04-25 11:47:05.548 Failed to load script: /Users/Shared/My DAZ 3D Library/Scripts/Pose Fusion/Pose Fusion.dse
    2020-04-25 11:47:11.650 Loading script: /Users/Shared/My DAZ 3D Library/Scripts/Pose Fusion/Pose Fusion.dse
    2020-04-25 11:47:11.651 Failed to load script: /Users/Shared/My DAZ 3D Library/Scripts/Pose Fusion/Pose Fusion.dse
    2020-04-25 11:47:18.530 Loading script: /Users/Shared/My DAZ 3D Library/Scripts/Pose Fusion/Pose Fusion Product Support.dsa
    2020-04-25 11:47:18.550 Script executed successfully: /Users/Shared/My DAZ 3D Library/Scripts/Pose Fusion/Pose Fusion Product Support.dsa
    2020-04-25 11:50:35.311 Loading script: /Users/Shared/My DAZ 3D Library/Scripts/Pose Fusion/Pose Fusion.dse
    2020-04-25 11:50:35.311 Failed to load script: /Users/Shared/My DAZ 3D Library/Scripts/Pose Fusion/Pose Fusion.dse
    Where it says "Script executed successfully," that refers to the Script "Pose Fusion Product Support" page, which brought me here, not to the Pose Fusion product.
    Thanks..looking into it.
    Hello! I am receiving this same error message. "An error occurred while reading the file, see the log file for more details" Was/is there a fix for this? I am on a Mac OS 10.11.6 El Captain
    What version of studio are you running?
    4.10.0.123. That could be the reason. I'll try using it on 4.12.... the latest but can't IRAY render but I'm able to with 4.10
    edited July 2020
    You need 4.12.0.86 minimum. We do not script build off older versions of studio since we do not have them installed. The script will only work in the versions it was built on and higher.
    Gotcha! thanks, It works in 4.12.1.118. Just can't render IRAY. Not your issue tho.
  • inquireinquire Posts: 2,460
    HI, I'm running DAZ Studio 4.12.1.118. My problem is referred to above, so I thought I'd put in the DS version I'm using. I'm on a Macintosh, running OS 10.12.6 (Sierra). Has Pose Fusion Plus been tested on a Macintosh?
    edited July 2020
    Yes it was tested on PC and Mac. Send me your logfile please.
    Oh, I don't have Pose Fusion Plus yet. I do have Pose Fusion. The Log File would be the one for Pose Fusion which Nick_1939 quotes above:
  • Hi
    I bought the bundled deal but the plus version is not showing up.
    How do I resolve this?
    Regards
    Bernard
  • jardinejardine Posts: 1,223
    random compliment:
    when i picked up pose fusion and pose fusion plus, i thought that they might be really useful once in a while.  as a niche tool.
    boy, did i underestimate the value of this tool.  i use it almost every time i pose a figure, these days.  and i'm still regularly impressed by how intelligently the interface is designed and how deep the capabilities of the script are.  the thing is worth its weight in gold if you're a pose fiend.
    so thanks!
    edited September 2020
    Thanks for the compliment. I'm using it now as we speak lol. Busy remaking some poses I want to use for promos:)
    Hi
    Regards
    Bernard
    Hi. What script are you using? I need a bit more info.
  • Hi,
    When I try to use Pose Fusion Plus on a Genesis 8.1F I get a message that basically says Genesis 8.1 is not supported although it is listed as supported on the product page. Am I missing something, or will Pose Fusion Plus be updated  to work with Genesis 8.1?
    Hmmm we did not make it 8.1 compatible yet. Looks like the store page auto added 8.1 support. We will address this. Thanks. The update hasn't gone live yet.
  • charlescharles Posts: 866
    Hi, I need this working for 8.1, I use it A LOT! Thanks!
    edited February 2021
    Here is the updated script. Just overwrite the old one. It's the same update thats stuck in q/a at the moment.
    zip
    zip
    Pose Fusion.zip
    50K
  • ChoppskiChoppski Posts: 675
    HI, will this or the plus work with DS 4.10?
    edited April 2021
    No. Think 4.12.0.86 is lowest.
    Latest version - 1.4
    Pose Fusion 1.4 Update Improved some MacOS GUI issues. Fixed issue where script would not be added to Scripts menu in rare cases.
  • leo04leo04 Posts: 409
    edited December 2022
    This is for Pose Fusion and Pose Fusion Plus.
    I don't get a dialog or anything when I load this, just a sound indicating some kind of error or incorrect input.
    I have to hit the ESC key to get out of it and continue working.
    What is happening and what can I do to correct the issue?
    This happens with both items.
    Thanks.
    Post edited by leo04 on
