More help needed for DUMMIES
cclesue
in The Commons
I purchased this item (HD Body Shapes for Genesis 8 Female) but once installed I can't seem to find the morphs. I wish the would give us dummies clear instructions on things like this.
Tip #1
When asking for help with a product, please provide a link to the product.
Tip #2
HD Body Shapes for Genesis 8 Female: (.DSF)
Tip #3:
Attachment contains a spoiler!
Try the Shaping Tab. Almost certainly, the settings are Actor> Full Body> Real World but if you select actor in the Shaping tab, and use the search at the top of the Shaping Tab and look for HDL. . if the parameters show up like "Athletic", you can click on the gear and learn its exact path.
This dummie thanks you but it turns out that DIM misinstalled (to long to explain as I don't want to appear even dummer.)
HDL would make sense, but nothing shows up.
I manually downloaded this item to skip DIM but even then I'm not getting them.
Try sreaching for "Athletic" on the shaping tab.
Don't forget you have to reload G8F after installing.
Now I' really confused reload G8f after installing what?
If you install a morph, the morph doesn't appear until a new figure is loaded since morphs are loaded only when a figure created.
That did it thanks
