More help needed for DUMMIES
cclesuecclesue Posts: 420
I purchased this item (HD Body Shapes for Genesis 8 Female) but once installed I can't seem to find the morphs. I wish the would give us dummies clear instructions on things like this.
  • SevrinSevrin Posts: 6,313
    Tip #1
    When asking for help with a product, please provide a link to the product.
    Tip #2
    HD Body Shapes for Genesis 8 Female: (.DSF)
    • This Product is Morph Dials Only
    • Athletic
    • Bold
    • Casual
    • Curvy
    • Slim
    Tip #3:
    Attachment contains a spoiler!
    488 x 586 - 67K
  • nemesis10nemesis10 Posts: 3,867
    Try the Shaping Tab.  Almost certainly, the settings are Actor> Full Body> Real World but if you select actor in the Shaping tab, and use the search at the top of the Shaping Tab and look for HDL. . if the parameters show up like "Athletic", you can click on the gear and learn its exact path.
  • cclesuecclesue Posts: 420
    This dummie thanks you but it turns out that DIM misinstalled (to long to explain as I don't want to appear even dummer.)
    HDL would make sense, but nothing shows up.
    I manually downloaded this item to skip DIM but even then I'm not getting them.
    Try sreaching for "Athletic" on the shaping tab.
  • HavosHavos Posts: 5,607
    Don't forget you have to reload G8F after installing.
    Now I' really confused reload G8f after installing what?
    If you install a morph, the morph doesn't appear until a new figure is loaded since morphs are loaded only when a figure created.
    That did it thanks
