DAZ Studio to ZBrush Error?
Fragg1960
For years I've been exporting elements of DAZ Studio scenes (mostly clothing) to ZBrush for minor tweaks and adjustments. I usually export the figure with deformations (so the pose comes over and I can tweak things like capes, drapery. etc.). I just tried it and the pose keeps coming over into ZBrush with the base figure T-pose which I've never seen before. No matter which DAZ export box I check off, the results are the same. Has anyone else had this happen? Not sure if it's a DAZ-Studio side issue on the export--I suspect it is, but I've been doing this for a long time and never had an issue. Any guidance would be appreciated.
Post edited by Fragg1960 on
If you haven't already, you could try clearing the cache folder. Typically this will be at C:\Users\Public\Pixologic\GoZProjects\Default
This always causes problems for me, so I clear it before every new DS _GoZ_ZB process.
