The "Powered by Hot Pockets" Complaint Thread
194959698100
  • LeatherGryphonLeatherGryphon Posts: 12,177
    edited July 2020
    Non-complaint:  Wheee..., I think I've found and fixed a long standing problem with my old computer.  For quite a while (and more noticeably after updating to the still unofficial win10-2004 update a few weeks ago) I've been noticing that sometimes when I use the "ThisPC" link or icon on the desktop to open up the FileExplorer dialog to look at the top level of my system (the drives & devices) the progress bar at the top would start to go green, and a message would appear saying "Working on it". frown Sometimes the green progress bar would finish quickly, sometimes it would never finish and I would not see my drives or devices at all.  Behavior was very erratic.  Sometimes OK, sometimes not and the only cure was to reboot. angry
    This is apparently a known problem from at least 2016 and more recently 2019.  Research on the Internet suggested that things were wrong with the "Quick Access" menu along the left side of the dialog.  One of the suggestions was to remove a particular hidden file. That didn't work for me.  But I began to believe that it was indeed related to the Quick Access menu.  So, I started removing the entries from the menu one by one.  Some would disappear quickly, others would take a minute or so then leave, others would take looooong time, and others appeared to never finish (I didn't wait more than about 10 minutes).  But I persisted.  And as I removed some of the entries I realized that many of them were links to folders in drives not currently mounted, but the links should disappear anyway.  Hmmm..., Then I realized that I was deleting far more links than I remember ever having put in the Quick Access menu.  I was not only unlinking a folder, but also many of the sub-folders of that folder.surprise  This tells me that either the QuickAccess menu was royally screwed up, or I had inherited links from the Win7 incarnation of my Windows installation.  But I persisted unlinking each new entry from the limited display space of the menu as it appeared when I deleted a previous one.  At a few points I had to reboot the system, but after a reboot, I could continue the deleting process.  Eventually I got all but one entry removed, and try as I might, it just wouldn't go, it just did nothing, didn't hang, didn't give error, just ignored the command to vanish.  I traced to the actual location of the linked folder and found that it was an empty unused unnecessary folder, so I deleted it and poof, it disappeared from the QuickAccess menu and now my QuickAccess menu is completely empty.  Yay! smiley
    Now, since I have completely emptied my QuickAccess menu the system behaves completely normally, and actually noticeably faster for all FileExplorer functions.
    My theory is that the QuickAccess menu got screwed up somewhere along the line, either by too many entries, or deleting a entry that forced the subfolders to generate entries, or a disk error bit me  or the 2004 update has a bug that exacerbates the problem, but for now, my system is working well again.  I suspect that when the FileExplorer dialog runs it has to check the links for all the entries in the QuickAccess menu but if the entries were boogered it could go down a thorny path.  From now on I'll carefully watch my use of the QuickAccess menu and keep an eye out for bogus behavior again.
  • TaozTaoz Posts: 10,285
    i'm trying to watch a video on computer programming but the host talks to fast.  Maybe I should buy a book and then read from the book.
    Please write a bit slower, I cant' read that fast...
  • Richard HaseltineRichard Haseltine Posts: 108,934
    Mystiarra said:
    Non-complaint:  Wheee...  My new replacement 7-port USB2 hub arrived today.  After one of my two old 7-port USB2 hubs died I've been kludged up with various cables rerouted to other ports or computers or just simply unplugged for almost 2 weeks.  But today I got my hands dirty, crawled behind the computer, untangled some wires, removed an unnecessary power brick, rethought my USB needs and was able to remove the other partially crippled USB2 hub (4 of 7 ports were dead) and consolidate all my USB2 needs into my new USB-7port hub and find some more visible desk space.  Call it a late spring cleaning.  All 7 ports of new hub tested and functional.  Yay!  Also all 8 USB2 ports in computer tested and functional. Double yay!!  Also, all 4 USB3 ports in computer tested and functional.  Triple yay!!!  And I still have the two USB2 ports on the front panel empty so there are no ugly wires snaking out of the front of my machine.  I'm in USB heaven again.  smiley  And the icing on the cake is that I have one and a half 7-port USB hubs squirreled away in a storage box for emergency use.  Yeah, yeah, I realize I could have just done all the rethinking and rewiring without ordering a new 7-port hub but, the two old hubs are over 12 years old, both the same model, and one was already half dead, so it was time.indecision
    7?!!
    Yes, 7.  The hubs are designed with two 4-port chips, one of the ports from one chip is used as the link back to the computer.  The other 7 are ports to connect to 7 other devices.   So, it's completely understandable why one of my two USB hubs had 4 ports die at the same time. Physics.  Something let the blue smoke out of one of the chips. smiley
    Surely it's not the ink back to the computer - the four port units have those - but rather the first four port is using one of its four connectors for the output from the other four port
    edited July 2020
    7?!!
    Well, I could be wrong, it's happened once before.surprise  But here's my reasoning.  The 8th or "extra" port has a USB mini-B female connector instead of the standard USB-A female.  Other hubs I've used would usually have a USB-B (the squarish one) female connector as the "link-back" (or "link-forward") connector depending on your point of view.  And I believe in the instructions it said to use the oddball connector and the included A to B cable for connecting to the computer.  Daisy chaining USB hubs could be done by using the odd connector to link-back from the far end of the chain to the hub immediately preceeding it.  But with only one hub in a chain, it would link back to the computer.  Regardless, that's how I use it and it works.  The dead ports on my bad hub were working fine one day until they didn't*, and had  nothing to do with linking one chip's port back to the previous chip.  In fact doing so would have effectively made that hub a 6-port system.  Now, whether this is the proper way to use those ports, I'm really can't say.  Perhaps the port on the computer is smart enough to know when it has to swap in/out signals when connected a forward or backward linking socket.  But using it my way works.  Perhaps I knew exactly how USB hub wiring should be done back when we didn't have smart ports but, well, you know, if you don't use it, you lose it.frown  For the last couple decades I've always assumed that a device with a "B" port was a "link-back" port from device (like a printer) to computer or previous device in the chain if applicable.
    If anybody knows for certain how those "B" ports are supposed to work.  Please let us know.
    * I don't actually know that my crippled hub has two 4-port USB chips inside.  I just assumed it did because of how it behaved.  It may have just one chip structured in two halves.  Regardless, four ports died simultaneously and my brain immediately went to two 4-port chips.
    Edited to add:   Well, I guess I could be wrong.  As I rewind my brain back to the mid '90s I get faint rememberings of one special port of a USB hub being used as a "link-forward" to the next hub toward the end of the chain.  I remember it because it would make one port unavailable for devices unless you found or made a cross-link adaptor.  Then hubs started being produced with a small switch to swap the in/out signals to make it a normal or reversed port, then eventually we got smart ports that could sense whether to swap in/out lines or not.  Again, regardless of a 25 year old design, the way I use hubs today appears to work.  I'd love to hear why it isn't optimal or what I'm misunderstanding about USB.
    Edited to add even more:  If my memory from the '90s is right then that is an example of why young people may think us old farts are slow.  Or perhaps I was wrong then, and correct now.indecision  We ancient ones have to deal with memories of additional ways of doing things that the youngsters have no experience with.  We've skinned a lot of cats.devil
    Or maybe I'm totally off-the-rails and am thinking about network hubs.  Ghaaaa, life was so much simpler before I learned to read.wink
    edited July 2020
    The "Computers are The Doom of Mankind, complaint thread."
    Non-complaint:  My old computer is behaving muchly better after I'd fixed the QuickAccess menu issue.  Zip, bang, zoom.  All disk oriented processes seem to be without lag anymore.smiley  Which they should be because the "C:" drive is an SSD.  I was wondering where the zip from my new SSD had disappeared to.surprise
    daleks have girls in them?
    is 3 days to the first eye surgery.  i starting on 2 different eye drops 3 times a day.  hopes isnt the stingy one
    theres an eye drops they put on me before the avastin injection, burns ick
  • starionwolfstarionwolf Posts: 3,670
    heatwave.  Outside thermometer reads 100 degrees F.  It is the beginning of July.  August is supposed to be hotter, I think.
    We need snow reports from the Australians.
    my poor lil pointsetta is on her last leaf.  was a hardy old gal
    basil on my sil growing like crazy.  think is called a riot when plants grow crazy
    GOOD MORNING AMERICA, it's the 4th of July!  Wheee...smiley  BBQ in the park, party on the beach, super new movies at the theater, jostling crowds at the fireworks...  oh, wait.., no, nevermind it's just another lockdown day.frown  But if you do go out, please wear a mask.  I do.yes   You don't put out a fire by ignoring sparks.
    And now for something completely different:  I saw fireflies last night.smiley  Yes, right in my backyard.  I know I complained a few months ago that I hadn't seen fireflies in years, but there they were last night.  Yay!  Not a terrible lot of them but they were sparkling in the bushes and gliding over the grass.  Wheee...smiley
  • Subtropic PixelSubtropic Pixel Posts: 2,388
    Up here in extreme western NY State we still have deer the size of deer, black bear, pheasant, fox, rabbits, groundhogs(woodchucks), beaver, wild turkey, squirrels, and chipmunks.  And those are only the critters I've actually seen in the wild, in the last decade, alive, and without getting more that 20 feet from a paved surface.
    But don't forget that Florida also has wild hogs!
    Yes, and they are a big problem.  They tear up farmland and gardens, and they kill livestock.  They rove in packs and can take out even a smart dog or a smart human.  There's only one way to protect oneself against wild hogs.  I'll leave that to you and your own research.
    Mystiarra said:
    the ovid test...
    Um, what?
    Ovid was a Roman Poet.
    Courtesy of https://en.wikipedia.org/wiki/Ovid
    Publius Ovidius Naso (Classical Latin[ˈpuːblɪ.ʊs ɔˈwɪdɪ.ʊs ˈnaːsoː]; 20 March 43 BC – 17/18 AD), known as Ovid (/ˈɒvɪd/ OV-id)[1] in the English-speaking world, was a Roman poet who lived during the reign of Augustus. He was a contemporary of the older Virgil and Horace, with whom he is often ranked as one of the three canonical poets of Latin literature. The Imperial scholar Quintilian considered him the last of the Latin love elegists.[2]
    Still doesn't make sense even in a more contemporary context...
    https://www.ovid.com/about-ovid.html
    About Ovid
    Ovid helps researchers, librarians, clinicians, and other healthcare professionals find important medical information so that they can make critical decisions to improve patient care, enhance ongoing research, and fuel new discoveries. We offer a market-leading medical research platform of premium aggregated content and productivity tools...
    Sometimes when we make up words, we overlap with the past or the present.
    In my area we have deer, fox, rabbits, groundhogs, wild turkeys, squirrels and chipmunks (I think those two are pretty much everywhere in New England).  In fact, my sister is visiting and she told me last night that a deer ran right by her, within reach, as she was standing outside her car.  I've seen fox on my street, as has my wife, and on three occasions I've seen coyotes.  Once during the daytime, in the winter.  I was shoveling snow in my driveway, got in the car to warm up for a minute, looked to my left and there he was, casually prancing across the street into my neighbor's yard.  I was glad I was inside the car.  No black bear, though.  But they are around in the greater Boston area and metro west area.
    And palmetto bugs!
    Dana
    Yes, all my aforementioned critters are seen throughout the northeast, but do your deer play tennis?  Or do your woodchucks assemble with the squirrels, chipmunks, rabbits and turkeys to form an orchestra?  The bears just sit back and watch.  Sorry, lost the video.indecision
    Down here, the Deer play hide and seek.  Squirrels play "chicken" with cars, and the cars often win.  The bears here, as mentioned above, just climb your tree and wait for you to come outside to play.  I blame bears for the downfall of the newspapers and I believe that "newspaper with my coffee" has become a lost tradition because of tree-bears.
    When I lived in Florida, I saw many eagles.  Driving across state, out in the boondocks, swamps, and cattle ranches, the eagles have nests at the top of the power lines.  There was even an eagle in the city of Melbourne that nested somewhere near our house.   Also, in the city of Melbourne, while in the hospital parking lot I watched a Great Horned Owl (big big owl) survey the land from a corner of one of the hospital buildings, then swoop down and grab some little critter from the weeds.
    Little critters should take care!
    Get the podcast and set it to 1/2X.
    McGyver said:
    Genuine complaint... on the 28th of JUNE I went into Target and they were putting in the "back to school" stuff...
    What the flippyfruck are these people thinking?... They removed all the summer stuff and are moving on to autumn.
    Boohooohooo... retail stores are dying... seriously? You stop selling relevant seasonal item a few weeks into the season and you wonder why you have problems.
    The 28th of June they moved on to back to school... Technically (if it wasn't for the lockdown) the last day of school around here would be between the 18th to the 22nd... so kids would get out of school and a week later the back to school crap is out... ?
    Geez.
    The schools will need to open soon or the parents will have to break labor laws and put the kids to work.
    Tjohn said:
    I generally find cat memes not funny and sometimes even boring.  But this one was good!
    Mystiarra said:
    complaint  Ovid test was awful.  swabbed my nostril.  there is no g spot in my nose  ugghy yuck icky poo
    cataract surgery is 6:30 am.  as if it wasnt already impossible to find someone wodrive me.  taxi to the place is 60bux.  the important part is someone to walk me out.  mebbe taxi driver will do it for a tip.  other problem is i'll never find the door into the place by myself.
    the blindness diet is pretty effective.
    been years since i seen anybody's face.  cant see my face in the mirror.  i think i still look like I did at 40  lol
    The Ovid test Complaint Thread
    Billy Blakelaugh
    Wow, to have developed a test...and working on a vaccine, that must mean that poets are even more annoying than I thought!   wink
    7?!!
    7 port hubs have been available for more than a decade now.  I have old ones by my keyboard controllers.
    Happy Independence Day to all!  Today is a day of decluttering for me.  I've already cleared one long-neglected corner and am starting on another.  By 09:30 this morning, I'd already shot one palmetto bug and one "reg'lar sized" cockroach with my 2-gallon bugsprayer stuff.
    The difference between a cockroach and a palmetto bug is this:
    • If you think you can arm wrestle it and win, it's probably a cockroach.
    • If you think you can arm wrestle it and lose, it's an NYC cockroach.
    • If it's almost the size of a sky bison and you're quite sure that you can saddle it up and ride it down to the corner store, then THAT's a Palmetto Bug!  By the way, spurs don't work on Palmetto Bugs.  Their shell is too thick.  You just have to put reigns on its horns and muscle it wherever you want to go.  Yip yip!  winklaugh
    complaint - rediculous amount of sugar in bbq sauce. and omg in real maple syrup.
     smiley
    cornbread doesnt grow on trees.  but shoes do!
    complaint - i'll have to put shoes on in a couple days.
    i'm purging my hamper, trash binning all socks and starting over with fresh new packets of diabetic socks.
    i've got cantalope for breakfast, lunch, and dinner.
    oasty buttery cornbred a tasty fantasy.  mebbe in a few days i can find things in the super market. find the checkout lines.
    i heard there are arrows on the floor for one way aisle traffic.
    heard my neighbor yelling at the bluejays, in english, the bjay squablles too loud for him.  bjays no habla
    i want to celebrate independence day, feel like i should be mourning all the dudes that died for it.
    how historically accurate is the patriot movie?  did they really burn those people in the building?
    Mystiarra said:
    the ovid test...
    Um, what?
    About Ovid
    And palmetto bugs!
    Dana
    Geez.
    Billy Blakelaugh
    7?!!
    yip yip the magic words for flying bison
    caught between the speaker wars of the neighbors
    the neightbor who was yelling at the bluejays for being noisy is blasting music about Soledad
    other side is blasting   rap with mean  lyrics
    it's not nap in the hammock music
    people get cataract surgery all the time.  it works?
    i could be reading a book in soon
     could be reading labels on dvd and can put em in the correct cases
    might be seeing the tatts on my arm
  • DanaTADanaTA Posts: 13,353
    Good luck!
    Dana
    edited July 2020
    Sending good thoughts for your cataract surgery.yes
    And now for something completely redundant:
    First photo of groundhog youngsters. And a photo of my Office/Livingroom/Life. indecision
    800 x 531 - 66K
    1000 x 750 - 86K
  • TJohnTJohn Posts: 11,352
    Jim Henson's Groundhog Babies.
    edited July 2020
    The Duplicate Post Complaint Thread
    Post edited by TJohn on
    "The I'm Just Going To Go Into a Corner and Cry, complaint thread"
    they re[lacw=ed lens of ny ete.  very blurry. dilated
    corner gettin crowded.
    edited July 2020
    Non-complaint:  Summer day.  Self isolating.frown  Staying cool, sipping iced tea, listening to https://www.youtube.com/watch?v=aW-7CqxhnAQ  The whole day is in the music, the kids in the park, the picnic by the stream, more people arriving, and the thunderstorm.smiley  And you don't even get wet.yes
    1. "Awakening of cheerful feelings on arrival in the countryside." 0:00
    2. "Scene by the brook." 10:51
    3. "Merry gathering of country folk." 22:40
    4. "Thunder, Storm." 28:29
    I thought I was self-isolating. It turned out people were just avoiding me. (drum roll, cymbal crash)
  • GordigGordig Posts: 10,645
    I was self-isolating before it was cool.
    from now on i'm only talking outloud to dogs.  prolly no one will notice.
    i seeing a little more detail, like seeing flutterbys in the yard.  cant read my phone at all.  cant see the time.
    holding off on the total despair.  see how things look in a few days.
    was looking forward to swapping 500gb drive with 2tb.  cant see the screws.
    I had my cataracts done early this year. I have to have reading glasses now (the cheap drugstore kind work fine), you probably will too. i can see to drive and watch TV without glasses though.
    i'd rather need glasses for distance.  they didnt offer me a choice.
    edited July 2020
    Typically what they do is insert fixed focus lenses in your eye, focused for middle distances like being able to navigate in your house.  But for long distances or near distances you'll need glasses.
    I've always worn glasses my whole life (well, since 6th grade anyway) but could see fine up close without them.  But after my cataract surgery all that close work became impossible without a pair of reading glasses from the drugstore.  I had to try a couple of different strengths until I found a strength that worked OK for me.  They're cheap (less than $10).  HOWEVER, I also went ahead and went to my optometrist and had a regular pair of glasses made with progressive focus lenses to fit my new prescriptions.  I use the prescription glasses for driving and wandering around outside when I want to see birds in the trees and then look through the bottom half of the lenses to read things in my hand, like grocery labels and phones.  I use my cheap reading glasses, for, well, reading and when sitting close in front of the computer.  No way around it, I had to get used to not being able to focus closely without glasses.  Bummer, but my life is well more than half over anyway, so it's not like I have to put up with it for 50 years.
    What you can do until you get your other eye fixed is to use a magnifying lens to see closely.  It's essentially what the cheap drugstore lenses do anyway.  The doctors will probably tell you that it will take a couple weeks for your eyes to heal and settle down into stable focus so don't order prescription glasses until both your eyes stabilize.  But the drugstore glasses are cheap so treat them as experiments until you get a pair you can live with.
    Actually, what I do for really close mechanical work at my desk/workbench is use one of those large circular lighted magnifying lamps on a spring loaded articulated extension arm.  When using that I don't have to use my drugstore glasses, there's enough ability to find a good focus with the magnifying lens.  AND there's a lot of light! yes
