Figure Metrics help request (Solved)
HaruchaiHaruchai Posts: 2,040
Can anyone help with a strange situation I have? I have Measure Metrics and Figure Metrics installed. For every figure I load other than Genesis 8 Female I get the boxes to edit the measurements. But with Genesis 8 Female they do not appear when I run the script. I appreciate that this is something to do with my Genesis 8 Female but I don't even know where to start looking to troubleshoot it. Genesis 8 Male works so it's nothing to do with them being the later figures.
Does anyone have any suggestions please?
Post edited by Haruchai on
  • Richard HaseltineRichard Haseltine Posts: 110,623
    There have to be properties associated with the measurements for a check box to appear - check the Configuration tab.
  • HaruchaiHaruchai Posts: 2,040
    edited July 2020
    Thank you Richard, that was indeed the issue. When the script loads when Genesis 8 Female is selected no configuration file is set. Setting it manually brings up the boxes to allow adjustment.
    Really appreciate your help.
