v9.0 -- mcjBuilderA - script to build anything in Daz Studio - updated sept. 16 2017
2456711
  • mCasualmCasual Posts: 4,607
    edited April 2014
    One ring to rule them all ( except the ones that dont want to )
    the progress is, closed profile and paths with proper UV layouts ... which can be tricky at the borders
    background panoramic image is by benjamint444
    at http://commons.wikimedia.org/wiki/File:Mist_-_Ensay_region3.jpg
    did you know there's more an more panoramic images in wiki commons?
    http://commons.wikimedia.org/wiki/Commons:Featured_pictures/Places/Panoramas
    1600 x 900 - 310K
    1600 x 900 - 703K
    Post edited by mCasual on
  • Miss BMiss B Posts: 3,071
    WOW, now THAT's a ring. Makes a nice stage for the rock star. :coolsmirk:
    edited April 2014
    i'll probably post some of the built things as props , since not everyone will want to use a script
    1200 x 1200 - 178K
    edited April 2014
    Kewl! :coolsmile:
    Post edited by Miss B on
    edited April 2014
    trying to use the mouldings builder script to 3d-model cushions
    t'would be hard to avoid having to use a 3d modeler lo complete the task ( welcing caps )
    but i'll at least fix the texture issue
    the second image is named "riding shogun" due to faulty pun reasons
    1200 x 1200 - 1M
    1200 x 1200 - 284K
    1200 x 1200 - 247K
    Oh now wouldn't that be nice. I like the way the rounded corners came out.
    edited April 2014
    so to recap you'll be able to select from a few (30?) moulding shapes
    or create your own in 3d modelers like Blender, or using a daz script like mcjLather
    then you'll select one of the built-in paths
    or create your own by writing a little text like this
    turn 90
    Move 1
    turn 90
    Move 1
    turn 90
    Move 1
    turn 90
    that's 4 90 degrees arcs and 4 straight segments ( the 4th is added by the script since the "closed path" option was enabled )
    927 x 1200 - 767K
    1009 x 381 - 26K
    1920 x 1080 - 1M
    edited April 2014
    good news ! after some effort i was able to pinpoint the source of the slight distortions that appeared in the mouldings textures !
    i was rounding off the texture coordinates to 1/1000, just to make the obj file look neater
    but this was throwing away too much precision
    ( because the moulding texture maps are very long and narrow )
    see the difference
    1 - rounding UV U to 1/1000
    2 - no rounding ( or something like 1/10000000000000000 )
    figure 3 ... see effects like this would've been ruined by this
    other advances : completed the code to load /save extrusion paths and to convert obj files into paths
    the path for the frame shown here was in fact an obj and once converted to mcjBuilderA's language it became
    927 x 1199 - 243K
    927 x 1199 - 1M
    927 x 1199 - 1M
  • RAMWolffRAMWolff Posts: 10,374
    You really aught to write a UV mapping program with this sort of thing in mind Casual. Like getting a flowing map on a deformed cape or skirt or other weird angles in clothing, organics and hard edged props. Just amazing work here.
    Wow, Richard, I like your idea. That would be a handy thing to have when UV mapping. :coolsmirk:
    edited April 2014
    last features i wanted to add
    - mirrored extrusion profiles
    so here the quarter-round moulding was used as an inside and an outside trim
    - welded/non-welded UVs
    so far the moulding textures were chopped up in tube sections
    this was useful for frames with 90° corners
    but for curvy mouldings, we don't mind a little stretching
    of the texture to obtain texture continuity
    1280 x 720 - 154K
    628 x 752 - 104K
    927 x 1199 - 282K
    927 x 1199 - 832K
    edited April 2014
    in some cases the texture stretching is not really a problem
    fig. 2 - added a few classic moulding shapes
    800 x 800 - 52K
    802 x 792 - 98K
    1200 x 900 - 677K
    edited April 2014
    the 50 moulding profiles that will be bundled with the script
    1920 x 1200 - 78K
    1920 x 1200 - 111K
    Those are nice!!! They look very useful. :coolsmile:
    edited April 2014
    thanks for your patiemce @ all following this thread
    soon ! is the word is the la la la
    a complex path, you can see most of the keywords understood by the script
    polygon count for this object is about 2000 frames
    Radius 0.25
    Hardturn 0
    Move 1
    turn 90
    Hardturn 0
    Move .05
    Hardturn -90
    turn 90
    Hardturn 0
    Move 1
    1920 x 1200 - 153K
    1920 x 1080 - 716K
    1920 x 1200 - 247K
  • none01ohonenone01ohone Posts: 862
    I'm sure the extra bells and whistles are well worth the wait. :-)
    493 x 335 - 29K
    edited April 2014
    tonight is the night
    after i add what's needed for stairs-handrails and check a few things, i'll post the script and write the "manual"
    this is a beta version, the next version will probably have improved stairs-handrails handling
    644 x 728 - 60K
    927 x 1200 - 179K
    927 x 1200 - 168K
    instruction manual writing in progress
    https://sites.google.com/site/mcasualsdazscripts3/mcjbuildera
    618 x 800 - 104K
    edited April 2014
    ** Beta Released ** Beta Released ** Beta Released ** Beta Released ** Beta Released ** Beta Released **
    manual is being written as we speak
    there will most probably be many updated versions in the next day(s)
    1200 x 900 - 99K
    618 x 800 - 119K
    908 x 908 - 54K
    WOOT!!!!! :coolsmile:
  • caravellecaravelle Posts: 2,718
    Thank you! I tried it immediately, and it works!!! Thousands of wonderful new posibilities!
  • WilmapWilmap Posts: 2,917
    Thank you for this. Works great.
    welcome !
    i'll probably finish writing the manual today, add a part that better explains how to write your own extrusion path ( scripts )
    or import them from objs
    welcome
    that 2 confirmations that it works ! :)
    i developed and tested in DS3A but, it uses things that exist in all versions since DS1
    note that i generated and packaged as props 71 straight moulding segments ----> http://www.daz3d.com/forums/discussion/39820/
    eventually the script will be able to produce good end-caps, for now it's open-ended tubes ( unless you make rings/frames )
    1920 x 1080 - 273K
    edited April 2014
    Thanks Casual. An awesome script, I will have some fun with this. Tried some your profiles which were fine, but came unstuck trying to use my own Blender profile as it only recognized half the profile. That was after applying the mirror modifier and removing the centre edge as well as ensuring it had one face. I'll have another go later.
    Cheers.
    /Edit. loaded up one of your preset obj's and modified it in Blender. Saved as a new shape, worked perfectly. Not sure what I did before but this worked out great. :-)
    Post edited by none01ohone on
    TOTALLY awesome. Thanks so much Casual!
  • SylvanSylvan Posts: 2,719
    Oh wow, I will totally dive into this tonight.
    Respect for your work!
    edited April 2014
    The instruction manual is now complete ( insert Yoda quote about completeness here )
    if you run the following script in the daz scripting editor
    it creates a random path
    for( i = 0; i < 100; i++ )
     d = Math.random() * 5
     debug( "Move\t"+d )
     dir = Math.random()
     if( dir < 0.5 )
     debug( "HardTurn\t90" )
     else
     debug( "HardTurn\t-90" )
    1920 x 1080 - 351K
    1920 x 1080 - 371K
    1280 x 720 - 94K
    recipe for a wrought iron C curl
    Radius .0
    Turn 360
    Radius .1
    Turn 90
    Radius .2
    Turn 90
    Radius .4
    Turn 90
    Radius .4
    Turn 90
    Radius .2
    Turn 90
    Radius .1
    Turn 90
    Radius .0
    Turn 360
    800 x 800 - 47K
    more complex curves ( like the Chateau de Sceaux balconies ! )
    the path has a slightl offset
    Radius 1
    Turn 90
    Move 1
    Turn 90
    Radius 2
    Turn 90
    Move 1
    Turn 90
    Radius 3
    Turn 90
    Move 1
    Turn 90
    Radius 4
    Turn 90
    Move 1
    Turn 180
    HardTurn -90
    Move 4
    Move 4
    HardTurn 90
    Radius 4
    Turn -180
    Move 1
    Turn -90
    Radius 3
    Turn -90
    Move 1
    Turn -90
    Radius 2
    Turn -90
    Move 1
    Turn -90
    Radius 1
    Turn -90
    Move 1
    Turn -90
    800 x 800 - 136K
