Show Us Your Bryce Renders Part 11
1…3738404243…100
  • adbcadbc Posts: 3,115
    Horo, Rieke77 : thank you.
  • spuddyspuddy Posts: 449
    Thanks everyone
    adbc i like them both and there is a lot of work put into number one but for my part I prefer the simplicity and composition of the second one,,,,,,, great stuff
  • mermaid010mermaid010 Posts: 6,289
    edited June 2020
    Adbc - I like both, awesome renders, well done.
    Post edited by mermaid010 on
    edited June 2020
    Thanks everyone
    Post edited by Chohole on
    edited June 2020
    back to normal
    1754 x 871 - 3M
    Post edited by spuddy on
  • HoroHoro Posts: 11,719
    spuddy - the vegetation is beautiful.
  • Rieke77Rieke77 Posts: 619
    @ spuddy - I agree with Horo.
    spuddy, mermaid : thank you.
    spuddy : cool landscape, great vegetation.
    edited June 2020
    Spuddy - wow beautiful landscape. Are the vegetation freebies?
    An Abstract of spheres and tori using a sky from the Exotic Hdri for Fantasy Skies and Sci-fi for lighting.
    600 x 600 - 416K
    mermaid - that came out very nice, beautiful colours.
    @ mermaid010 - this is an very beautiful abstract render.
    mermaid : awesome colours, very nice abstract.
    edited June 2020
    Thanks Horo Thanks reike77 Thanks adbc
    Thanks mermaid010,,,,,,vegetation yes the daisies the white flower and the large grass in the foreground are free to use png images....the fine grass is my own particle brush
    below are the layers used to put the picture together ....but layer four is in fact made up of 9 layers each element is on a seperate layer to enable movement of them ...hope that explains thing a little
    ps layers two three and four actually have transparent backgrounds Ie the black is transparent but i saved them as jpg so they would show up better
    1754 x 871 - 1M
    1754 x 871 - 900K
    1754 x 871 - 839K
    1754 x 871 - 684K
    mermaid  Great abstract  lovely movement in the cols and reflections the Hdri sky has a big impact on it
    trying out 2 new materiasl  one render  grassy..... one render  sandy  and a mixture of both so excuse the scene
    1754 x 875 - 2M
    1754 x 875 - 3M
    1754 x 875 - 3M
    edited June 2020
    grassy
    sandy
    mixture
    Thanks Horo, Reike77, Adbc and Spuddy for your nice comments.
    Spuddy - wow that's fantastic how you put everything together. Thanks for your explanations. So far I never succeeded in adding nice vegetation either using objects or images. With your permission, I would like to use the two vegetation ones. Your latest examples, trying out different materials are also nice.
    Thanks mermaid010 I have no problem with you using them but you will need these png images below...Is there a place to share things like this?
    1754 x 871 - 1M
    1754 x 871 - 1M
    edited June 2020
    mermaid or anyone really here are some more bits and pieces made from my own particle brushes
    907 x 546 - 75K
    907 x 546 - 96K
    1000 x 1000 - 56K
    1000 x 1000 - 46K
    1000 x 1000 - 88K
    1000 x 1000 - 403K
    1000 x 1000 - 706K
    1000 x 1000 - 62K
    1000 x 1000 - 50K
    907 x 546 - 130K
    1000 x 1000 - 370K
    907 x 546 - 31K
    1000 x 1000 - 122K
    1000 x 1000 - 96K
    907 x 546 - 215K
    907 x 546 - 361K
    1000 x 1000 - 106K
    Spuddy - thanks a ton. I don't think there is a way to share on the forum, some members upload to Dropbox or ShareCG if they wish to share files. In this case I'll save the enlarged images and try. Thanks again.
    edited June 2020
    What other software do you have to add  resize move etc to the bryce image?
    Thanks once again Spuddy.  I use an ancient version of Photoshop, as ancient as I am, laugh but it is still good for my needs. I have lots of 2D png images, but I am not as successful as you have been in using them in Bryce.
    @ spuddy -  I also downloaded your particle brushes.
    Thank you very much for that. They're really great. yes
    spuddy : Very nice trying out materials .
    spuddy - very nice objects. I am not a fan of billboards, though at rare moments I use them for far away objects (a forest or so). Nevertheless, it is easy to create them directly in Bryce, no other program (Photoshop, Gimp, ...) is needed. Here are the steps:
    Making a Billboard
    - Create the objects you want to create a billboard from, say a tree.
    - Render scene with tree and export image as test0.BMP.
    - Select the objects you want on the billboard, example the tree.
    - Render as Object Mask and export image as test1.BMP.
    Using Billboard
    - Create a Leo (this creates a 2D-Face with the aspect ratio of the pictures).
    - In the Mat Lab, set a dot in Diffuse, Ambient and Transparency.
    - This creates a random texture.
    - On the texture, click on P (lower border second from left) to select the Pictures Lib.
    - On the texture, open the Pictures Lib (upper border second from left).
    - In the Pictures Lib, select a free square (usually next to Leo), this opens the Open dialogue.
    - Select the rendered picture test0.BMP. It appears in the left most window above.
    - Click on Load on the second (middle) image to open the Open dialogue.
    - Select the rendered object mask test1.BMP, on the centre window you see a white object on a black background.
    - In the rightmost window, you see the object isolated.
    - With Diffusion and Ambience, the brightness can be adjusted.
    - Check that the Mapping Mode is Parametric (far right button at lower border of the texture (already set if 2D face was created with Leo).
    - Check in the Material Options (down arrow left of first texture) that Blend Transparency is checked (already set if 2D face was created with Leo).
    - Exit the Mat Lab and adjust the size and position.
    The reason I seldom use billboards is because they are 2 dimensional and I cannot use one made in daylight in an evening or night scene.
    edited July 2020
    I like to use 2D images, especially to add people in my renders for the challenges, but so fair I did not have much success with them.
    A re-render of a previous sunset scene using one of the Hdris from the Landscapes under Fantastic Skies.
    900 x 675 - 478K
  • @mermaid010: Lovely. Maybe the water could have a tiny little bit of waves to separate it better from the sky, but maybe this was just you intention not to show it clearly.
    Thanks for your comment and suggestion, Electro-Elvis. I was going for a mirrored effect, I'll try with a bit of bump.
    @ mermaid010 - what a wonderful scene! I like the sky.
  • SlepalexSlepalex Posts: 911
    Very noticeable perspective distortions of 2D bird billboards. 2D images should be perpendicular to the view from the camera.
