[Released] Shapeless Morphs for Genesis 8 Male
jowolfjowolf Posts: 67
Hi!! I would like to show you my new product coming soon in Daz store:
"Shapeless Morphs for Genesis 8 Male" brings you over 100 morphs to change your genesis 8 body in shapes never seen before, modifying feet, legs, torso, arms, hands, head and face.
You can get unlimited shapes in seconds when you change the intensity of the morphs or when you mix them, trying different body part combinations for your characters.
Get Shapeless Morphs for Genesis 8 Male and start creating! :)
GENERAL QUESTIONS
Can I use  G8M Materials? YES, you can use materials for Genesis 8 Male such as Michael 8, diego 8, etc. these morphs don't affect them. I uploaded some photos as examples in comments :)
Can I move my character to create poses? YES, first load the morphs that you need in the character, then move hands, neck, legs, etc as you normally do it to create your pose.
Can I use pose presets for G8M? YES, you have 2 options: use one of the saved "set presets" provided in this pack, those settings come ready to use pose presets on the character. The second option is locking the invisible nodes, for example, If you want a character without a hand, you should select the hand and all its following nodes or "Children"(in this case, the fingers), then go to Edit-Figure-Lock-Lock selected node pose, now apply the correspondent morph (which hides the hand) and you will be ready to use the pose presets. If you are using morphs that don't hide body parts you won't need to do this process.
Post edited by jowolf on
  • lana_lasslana_lass Posts: 520
    Okay, I literally didn't realise I needed this BUT I TOTALLY NEED THIS! laugh This is definitely an "endless possibilities" product and will totally open up modelling within studio, so it'll be an instabuy for me. As will Shapeless for G8F if that'll follow winkyes
  • LeanaLeana Posts: 13,615
    Pretty cool product :)
  • PlantPlant Posts: 127
    Look's interesting would be good to see how or if it distortes the texture maps
    Yes, will normal texture maps work with this, or will materials come with it (like wax, etc)? For example, if I want to take a G8 character I created and use these morphs, will the skin still look okay?
    Also, will you be doing one for G8?
  • jowolfjowolf Posts: 67
    edited June 2020
    Thanks for your comments and doubts :) I am working on G8F version, I will post it as soon as I finish it ;)
    Yes! You can use all the Genesis 8 Male texures, I leave you some examples of how it looks with Genesis 8 Male, Michael 8 and Owen 8 textures, The distortion will depend of the morphs used, but in general is minimal, it just affects the place where the morph is loaded. You can check the following explamples.
    If you have more doubts just let me know :)
    1700 x 1000 - 1M
    1000 x 1000 - 612K
    1000 x 1000 - 612K
    1000 x 1000 - 558K
    1000 x 1000 - 571K
    1000 x 1000 - 791K
    1000 x 1000 - 885K
  • OstadanOstadan Posts: 1,133
    Is this general enough to use to simulate the sort of face appliances used in Star Trek for Klingons, Cardassians, etc.?
    Hi! Textures for Genesis 8 Male such as Michael 8, Owen 8 or G8M are working :) so if you created your own textures they should work,  you can check some new images I uploaded above as example. But If you want to use your character morphs you must be careful because the base is the G8M shape, it just depends of the extra morphs that you are adding and the intensity of it. (Textures still should work fine)
    Hi!  I am not sure what effect you want to get but all morphs are showed in Promo images, If you want to distort your character face it should work. :)
  • xyer0xyer0 Posts: 6,518
    Wow, if only you could have teamed up with FenixPhoenix to have a joint release where she did some texture appliances for wounds (for battle scenes or urban disasters).
    Product has been released! :)
  • CitizenMCitizenM Posts: 39
    edited May 2021
    I noticed in the promo images one has the nose removed and another has the ears removed. For the life of me, I cannot find how to do either and I need both. Is there any help for me? Thank you.
    Post edited by CitizenM on
