Issue with Cayman Studios Legacy UV's :SOLVED
carrie58carrie58 Posts: 4,173
I  suddenly have a problem with the geografts for Cayman Studios Legacy UV's  for Genesis 3&8 ......every where the geo grafts are warp, when the figure is posed. I can pose the figures then apply the geografts and texures but I can't change the pose once the geografts are applied and while I know it's been a while since the last time I used it ,I don't remember having this problem...... and it is happening with male and female figures ......help?
Post edited by carrie58 on
    edited June 2020
    Only select the figure when applying the pose [i.e. do not include the geografts in the selection]. Then they appear to work fine.
    1017 x 731 - 147K
    Post edited by Catherine3678ab on
  • carrie58carrie58 Posts: 4,173
    Thank you Catherine3678ab I will try that
