Wet, Sweat & Rain [Commercial]
2»
  • RuphussRuphuss Posts: 2,631
    edited March 2014
    blind sorry
    Post edited by Ruphuss on
  • Carola OCarola O Posts: 3,862
    @ Hera - I actually used it on both Olympia and M6 on this picture, admitingly the pic could probably be better but it worked somewhat :)
    2000 x 1125 - 296K
  • LinwellyLinwelly Posts: 6,070
    Would this work on a self dialed skin? I used skin builder pro for genesis and genesis 2 females, as far as I understood that product is based on the vicky 5 skin.
  • FlipmodeFlipmode Posts: 950
    Hi Linwelly ... I am sorry but I don`t really know what a self dialed skin is. ;)
    Maybe you find the info you`d need here:
    http://flipmode3d.com/fm-wetmaps-info/
    Basicly it boils down to
    You can use the wetmaps with any skin that uses either the “Base Female” or “Victoria 6″ UV-Set. Skins which use the UberSurface shader work out of the box, those using alternative shaders will require some adjustments.
  • CybersoxCybersox Posts: 9,912
    Linwelly's referring to using this: http://www.daz3d.com/skin-builder-for-genesis-and-genesis2-female-s ;
    Ah, thanks Cybersox.
    Well skinbuilder seems to use Victoria 5 UVs, the wetmaps use Base Female / Victoria 6.
    Then again the Skin Builder description talks aboue LIE, so I don`t know if that`s just an overlay over other skins.
    Linwelly ...I`d say if it remains unclear you could give it a shot and return it if it doesn`t work.
    I only returned one item ever, but that was handled smooth by Daz.
  • Oso3DOso3D Posts: 15,115
    I've returned a bunch of things, no problem.
    It's extra fast if you ask for store credit.
    Ok, Sorry for the late reply I was away for some days. So, yes as far as I understand the Skin builder used Viktoria 5 as a basis the changes are made to the diffuse, specularity, etc but the makeup and eyebrows come as a LIE.
    Then again as I understand the Victoria skin uses the ubersurface shader. I will try and find the info about that and the probably will give your wet skin a try. I did manage to create a drop like thing on the skin which wasn't looking too bad but the hassle of getting the drops to the right direction....
    Thanks for the help so far.
