impossible to open a victoria4 project !
hello community,
i am working on a victoria 4 based project, and since last week i can't open it anymore !! DAZ is crashing when opening, the log :
Loaded file: swing_forward_swing_forward_5883.dsf
Json Parser (44,19): Unhandled exception during parsing.
Error reading file, see log for more details.
Json Parser (4667,5): Unhandled exception during parsing.
Json Parser (3861,5): Unhandled exception during parsing.
Json Parser (4806,5): Unhandled exception during parsing.
Json Parser (4091,5): Unhandled exception during parsing.
Loaded Morph Deltas in 0 min 0.0 sec.
Loaded file: R_cheek_out_R_cheek_out_618.dsf
Loaded file: L_front_forward_L_front_forward_2393.dsf
Loaded file: R_front_forward_R_front_forward_261.dsf
Json Parser (2519,5): Unhandled exception during parsing.
Loaded file: L_front_pullback_L_front_pullback_2075.dsf
what's the problem ? can it be a recent windows update or daz problem ??
please help me i need to continue working on this project !!
That looks as if the files are corrupt - you may be able to restore them via your operating system's back up, or by loading the content into a new scene and saving that (since it's conversions of the original Poser files that appear to be at issue).
ok i don't know what happened but i can open my files now... ouf ! thanks
known issue with saved files
do not keep writing over your save file, eventually it will corrupt and not be useable.
save them more than once with different names.
example
save1
save2
save3
ect.....
well problem is still here... i don't know how i did last time to open my file, but it doesn't work anymore !!!
@ssweete that's what i did... i have 4 files of the same project, all of these are crashing daz at the end of loading resourses...
any idea ? is it safe to work with daz ? i am thinking changing software now
here is my log... eveything seams to be ok, but after loading all ressources and morphs, it crashes !
*** Scene Cleared ***
File loaded in 0 min 13.4 sec.
Loaded file: sophie6_anim_c.duf
Loaded file: Blouse Front Up_abdomen_Blouse Front Up_558.dsf
....(i don't put all the ressources)
Loaded file: JCMKneeBendL_lShin_JCMKneeBendL_941.dsf
Loaded file: FBMThin_lShin_FBMThin_1675.dsf
CRASH !
+++++++++++++++ DAZ Studio 4.6.2.118 starting +++++++++++++++++
Platform bits: 64
Qt Version: 4.8.4
Running on Windows 7, Build 7601, Service Pack 1
CPU Information:
CPU String: GenuineIntel
CPU Brand String: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz
Cache Line Size = 64
L2 Associativity = 6
Cache Size = 256
Stepping ID = 9
Model = 10
Family = 6
Extended model = 3
CLFLUSH cache line size = 64
APIC Physical ID = 2
Supported CPU Features:
SSE3 New Instructions
MONITOR/MWAIT
CPL Qualified Debug Store
Thermal Monitor 2
x87 FPU On Chip
Virtual-8086 Mode Enhancement
Debugging Extensions
Page Size Extensions
Time Stamp Counter
RDMSR and WRMSR Support
Physical Address Extensions
Machine Check Exception
CMPXCHG8B Instruction
APIC On Chip
SYSENTER and SYSEXIT
Memory Type Range Registers
PTE Global Bit
Machine Check Architecture
Conditional Move/Compare Instruction
Page Attribute Table
Page Size Extension
CFLUSH Extension
Debug Store
Thermal Monitor and Clock Ctrl
MMX Technology
FXSAVE/FXRSTOR
SSE Extensions
SSE2 Extensions
Self Snoop
Hyper-threading Technology
Thermal Monitor
Pend. Brk. EN.
Physical Memory:
Total: 5.8 GB (6322479104)
Avail: 2.0 GB (2227830784)
Virtual Memory:
Total: 7.9 TB (8796092891136)
Avail: 7.9 TB (8795875217408)
Current Memory Usage: 64%
Current DateTime:
Loc: mer. 26. mars 13:11:54 2014
UTC: mer. 26. mars 12:11:54 2014
Temp Data:
Location = C:/Users/nobox/AppData/Roaming/DAZ 3D/Studio4/temp
Disk Total: 419.1 GB (450071887872)
Disk Avail: 15.1 GB (16307638272)
Locale: fr_FR
No translator found.
i think it may be a tdlmake.exe problem... when i try to load materials on a fresh victoria it crash and says something about tdlmake.exe stoping working
