impossible to open a victoria4 project !
g_zab_g_zab_ Posts: 0
hello community,
i am working on a victoria 4 based project, and since last week i can't open it anymore !! DAZ is crashing when opening, the log :
Loaded file: swing_forward_swing_forward_5883.dsf
Json Parser (44,19): Unhandled exception during parsing.
Error reading file, see log for more details.
Json Parser (4667,5): Unhandled exception during parsing.
Json Parser (3861,5): Unhandled exception during parsing.
Json Parser (4806,5): Unhandled exception during parsing.
Json Parser (4091,5): Unhandled exception during parsing.
Loaded Morph Deltas in 0 min 0.0 sec.
Loaded file: R_cheek_out_R_cheek_out_618.dsf
Loaded file: L_front_forward_L_front_forward_2393.dsf
Loaded file: R_front_forward_R_front_forward_261.dsf
Json Parser (2519,5): Unhandled exception during parsing.
Loaded file: L_front_pullback_L_front_pullback_2075.dsf
what's the problem ? can it be a recent windows update or daz problem ??
please help me i need to continue working on this project !!
  • Richard HaseltineRichard Haseltine Posts: 111,325
    That looks as if the files are corrupt - you may be able to restore them via your operating system's back up, or by loading the content into a new scene and saving that (since it's conversions of the original Poser files that appear to be at issue).
  • g_zab_g_zab_ Posts: 0
    edited March 2014
    ok i don't know what happened but i can open my files now... ouf ! thanks
    Post edited by g_zab_ on
  • ssweetessweete Posts: 115
    known issue with saved files
    do not keep writing over your save file, eventually it will corrupt and not be useable.
    save them more than once with different names.
    example
    save1
    save2
    save3
    ect.....
    well problem is still here... i don't know how i did last time to open my file, but it doesn't work anymore !!!
    @ssweete that's what i did... i have 4 files of the same project, all of these are crashing daz at the end of loading resourses...
    any idea ? is it safe to work with daz ? i am thinking changing software now
    here is my log... eveything seams to be ok, but after loading all ressources and morphs, it crashes !
    *** Scene Cleared ***
    File loaded in 0 min 13.4 sec.
    Loaded file: sophie6_anim_c.duf
    Loaded file: Blouse Front Up_abdomen_Blouse Front Up_558.dsf
    ....(i don't put all the ressources)
    Loaded file: JCMKneeBendL_lShin_JCMKneeBendL_941.dsf
    Loaded file: FBMThin_lShin_FBMThin_1675.dsf
    CRASH !
    +++++++++++++++ DAZ Studio 4.6.2.118 starting +++++++++++++++++
    Platform bits: 64
    Qt Version: 4.8.4
    Running on Windows 7, Build 7601, Service Pack 1
    CPU Information:
    CPU String: GenuineIntel
    CPU Brand String: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz
    Cache Line Size = 64
    L2 Associativity = 6
    Cache Size = 256
    Stepping ID = 9
    Model = 10
    Family = 6
    Extended model = 3
    CLFLUSH cache line size = 64
    APIC Physical ID = 2
    Supported CPU Features:
    SSE3 New Instructions
    MONITOR/MWAIT
    CPL Qualified Debug Store
    Thermal Monitor 2
    x87 FPU On Chip
    Virtual-8086 Mode Enhancement
    Debugging Extensions
    Page Size Extensions
    Time Stamp Counter
    RDMSR and WRMSR Support
    Physical Address Extensions
    Machine Check Exception
    CMPXCHG8B Instruction
    APIC On Chip
    SYSENTER and SYSEXIT
    Memory Type Range Registers
    PTE Global Bit
    Machine Check Architecture
    Conditional Move/Compare Instruction
    Page Attribute Table
    Page Size Extension
    CFLUSH Extension
    Debug Store
    Thermal Monitor and Clock Ctrl
    MMX Technology
    FXSAVE/FXRSTOR
    SSE Extensions
    SSE2 Extensions
    Self Snoop
    Hyper-threading Technology
    Thermal Monitor
    Pend. Brk. EN.
    Physical Memory:
    Total: 5.8 GB (6322479104)
    Avail: 2.0 GB (2227830784)
    Virtual Memory:
    Total: 7.9 TB (8796092891136)
    Avail: 7.9 TB (8795875217408)
    Current Memory Usage: 64%
    Current DateTime:
    Loc: mer. 26. mars 13:11:54 2014
    UTC: mer. 26. mars 12:11:54 2014
    Temp Data:
    Location = C:/Users/nobox/AppData/Roaming/DAZ 3D/Studio4/temp
    Disk Total: 419.1 GB (450071887872)
    Disk Avail: 15.1 GB (16307638272)
    Locale: fr_FR
    No translator found.
    i think it may be a tdlmake.exe problem... when i try to load materials on a fresh victoria it crash and says something about tdlmake.exe stoping working
