WASD Movement input lag
Hey there,
I'm having a very weird issue after I installed the latest DAZ Version 4.12 (Not the beta).
It's not an performance issue as I can move around absolutely smoothly when holding the buttons at the top right of the viewport for moving or orbiting around. However when using WASD I get input lag of about a second. Meaning for example I press A to move sideways but it takes a second for it to actually move.
What can this be? Thank you!
Edit: I noticed that I can even move this way when disabling keyboard navigation which is weird.
Edit 2: I don't have this problem when I switch the viewport to fullscreen mode...
Post edited by Anxaer on
Try the beta, it has some fixes designed to address these issues.
Thank you, the beta actually fixes it. Thought it'd be the other way around :D
Currentlly the beta is newer than the general release (in part because of testing the fixes for issues like this) - sometimes there iisn't a public build and it will be the same version, it is not usually an older version.
