WASD Movement input lag
AnxaerAnxaer Posts: 12
Hey there,
I'm having a very weird issue after I installed the latest DAZ Version 4.12 (Not the beta).
It's not an performance issue as I can move around absolutely smoothly when holding the buttons at the top right of the viewport for moving or orbiting around. However when using WASD I get input lag of about a second. Meaning for example I press A to move sideways but it takes a second for it to actually move.
What can this be? Thank you!
Edit: I noticed that I can even move this way when disabling keyboard navigation which is weird.
Edit 2: I don't have this problem when I switch the viewport to fullscreen mode...
Post edited by Anxaer on
  • Richard HaseltineRichard Haseltine Posts: 112,003
    Try the beta, it has some fixes designed to address these issues.
  • AnxaerAnxaer Posts: 12
    Thank you, the beta actually fixes it. Thought it'd be the other way around :D
    Currentlly the beta is newer than the general release (in part because of testing the fixes for issues like this) - sometimes there iisn't a public build and it will be the same version, it is not usually an older version.
