Rakshasa: Not what I was expecting.
So recently I purchished Rakshasa for Genesis 8 male and female. They are tiger characters and thought they would look cool in a scif render. The examples given certainly made theme look that  way. Onely one problem. Here is what the product looks like:
https://www.daz3d.com/rakshasa-with-dforce-hair-for-genesis-8-male
And here is a quick test render using a poser 4 figure as comparasion. Not exactly the same thing. This is rendered in 3Delight. I've tried different mats and it doesn't make any difference. Not exactly sure what's going on.
  • zombietaggerungzombietaggerung Posts: 3,921
    I don't think they have 3dl materials. You'd have to convert them from iray to 3dl yourself.
  • RawArtRawArt Posts: 6,180
    dForce hair does not play nice in 3DL....there is no way to attach texture maps to the hair uv's...so they can only be one solid colour.
  • I don't think they have 3dl materials. You'd have to convert them from iray to 3dl yourself.
    That might be doable. How do I go about doing it? I've looked at the textures and there's really nothing to them. Meaning there's no detail at all.
  • Oso3DOso3D Posts: 15,114
    Yeah, there's no way to texture dForce Hair in 3dl. Pick a solid color you like.
    Even without the hair trying to find a texture that looks good is touch and go. If there was a texture converter I could just convert an older texture and this wouldn't be a problem. I have tried rendering itr using the other method but that takes over an hour for a single image on my machine.
    Maybe a fiber hair shader for 3dl would help? This is a bit expensive, but it has hair shaders for 3dl.
  • Well, here's your update. I was able to track down a feline texture for genesis 3 female that's compatable with Genesis 8 female called Cat Lyn. You can buy it on site. While it's not quite a perfect match it's the best I can come up with so far.
    1280 x 979 - 744K
  • PtropePtrope Posts: 696
    How does the figure look if you use the textures and hair, but not the cat head morph? More "furry" than "full-on feline?"
    With the fur, texture but not the head morph it's just human.
