Daz 4.12 GPU Rendering Issues
2»
  • BobvanBobvan Posts: 2,653
    edited June 2020
    Wallace3D said:
    Bobvan said:
    For the most part my 2080ti has been faster overall but ran into my 1st reaaally long render appox 6 to 8 hours. 3 Characters HRDI background taking forever for lines to clear off.
    That scene would have taken an hour to render on my setup with a resolution of 4096 x 4096. Now if I did not have my 1080ti and rendered it on my i7 5930K it would probably take 2 - 3 hours with a CPU limit of 10 of the 12 threads
    Okay why was it taking me so long? I have 2080ti &  i7 10 core processor 32G.. Just try to see what I may have missed? The scene was clear within minutes if you look closely on character skin there are these little lines that took a long time to clear..
    Post edited by Bobvan on
  • Wallace3DWallace3D Posts: 170
    Set it to memory instead of Speed?
    What setting?
  • AkaHasturAkaHastur Posts: 10
    Same problem here since I've installed the last version of Daz in order to be able to use dforce hair... No more rendering :(
  • Richard HaseltineRichard Haseltine Posts: 108,693
    If the render looks done then stop it, Iray is not able to truly identify a finished scene so it uses an algorithm to guess.
    Bobvan said:
    What setting?
    Instance Optimisation in render Settings, I think.
    What are your system specifications? Assumgn this is a Windows system with an Iray GPU what is your driver version? What were your settings for GPU/CPU in the Advanced tab of Render Settings?
    edited June 2020
    Bobvan said:
    What setting?
    So its just aimlessly running?  The lines do smooth over time but sooo slow. The progress bar did show almost done within 15 minutes in the scene window. What is interesting is the same scene with more of a closeup took a fraction of the time.
    I fond the mem setting! Its on Auto right now will experiment. Should I change the ray tracing low memory on using a 2080ti?
    1860 x 950 - 3M
    Bobvan said:
    What setting?
    Probably not, although if you are running out of memory it may be worth a shot. However, it does give a slower render than the standard mode so if you don't need it it's better left to Auto/Off.
    edited June 2020
    Bobvan said:
    What setting?
    Kinda thought so. Switching from 1/4 to normal in the iray preview has resolved the not being to use the wheelmouse issue.
  • JoJoSJoJoS Posts: 50
    edited June 2020
    I was hoping someone could help me. I upgraded to 4.12 the other day and ever since I cannot render what so ever, in fact I can't even spot render, Daz just closes to desktop. I have tried uninstalling and reinstalling, didn't work, I have checked graphic card updates, they are fine. I tried to roll back but I cannot access the Daz download page for god knows what reason, I have put in a support ticket and had nothing back. I'm at a loss and very very frustrated, any help would be appreciated. I'm on windows 10 btw with Nvidia if that helps. Thank you in advance!
    Post edited by JoJoS on
    What is your driver version - right-click on the desktop>nVidia Control Panel, the number appears in the coloured box just above the card name(s)
    edited June 2020
    I did as stated above and I get a the control panel except it has nothing to do with drivers from what I can tell, just screen and audio options.
    Update: However I looked in the gforce experience app and the lastest one thats available that I installed is version 446.14
    1334 x 932 - 90K
  • kenshaw011267kenshaw011267 Posts: 3,805
    You're going to have give us details on the system and what ever info is in the log.
    This is the case for every issue. To have a reasonable chance of helping most people we need to know"
    GPU and driver version
    CPU and RAM as well in many cases.
    OS and version.
    The log file from the error.
    From there people can make a reasonable attempt at helping.
    So sorry, my english is not so good, and i'm a complete dumb when it comes to technichal details :( I never change any setting when I want a render, only the size of the final picture. It always worked until i installed the latest version of Daz in order to use dforce hair.
    566 x 324 - 66K
    edited June 2020
    That's Mac, not Windows. Although I think it should still be working in this version nVidia has marked CUDA support for macOS as deprecated, meaning it will go away and CPU will be the only option. In the meantime, you may want to post to https://www.daz3d.com/forums/discussion/16599/the-mac-faq#latest
  • fastbike1fastbike1 Posts: 4,079
    edited June 2020
    @Bobvan "What setting?"
    In Render Settings>Optimization. See Attached.
    688 x 764 - 60K
    Post edited by fastbike1 on
    edited June 2020
    Found it yesterday thanks & as I mentioned changing changing normal from 1/4 in draw settings, the iray preview resolves the blurry problem using mouse wheel to zoom in & out.
    I am going to be expanding my system RAM from 32 to 64 this weekend.
  • DondecDondec Posts: 243
    edited June 2020
    NOTE:  The latest Nvidia Driver (446.14) fixed my IRAY issues with my Nvidia Titan X !!   DS now back in action.
    Thank you.
        Don
    Post edited by Dondec on
