Shopping for Shoes!
missuskisses
in The Commons
OK, I have had no luck searching my library or the store, so hoping some of you may be able to help me! I'm looking for strappy high heels, like gladiator sandals but high heels.
https://www.daz3d.com/eleia-outfit-for-genesis-8-females: Looks like what I want from the front, but the back part isn't quite what I'm looking for. I'd like for it to be straps all around.
https://www.daz3d.com/dforce-free-spirit-outfit-for-genesis-8-female-s: Same as above, and would prefer something less wedge-heely.
Any recommendations?
Thanks so much!
Goddess Minerva, but it's a wedge. https://www.daz3d.com/goddess-minerva-outfit-for-genesis-8-female-s
I know there's more, though... I'll have to look through my library.
Thanks! I do have that one, but it also looks like it's just separate straps. I forgot to specify that I'm looking for criss-crossing straps. But thank you for looking through your library!
You might look at some of Arryn's shoes and boots at rendo. There are several that might be what you want.
There's these, but they're wedge: https://www.daz3d.com/wrap-wedges-for-genesis-8-females Depending on if they have separate material zones on the wedge and bottom part, you could kit-bash them together with regular high heels, reducing the cutout opacity to zero on the wedge part of the shoe. Then using the same shader on both the high heels and the wrap wedges shoes. OR using just the wrap-around straps with a pair of regular high heels. Again though, that would depend on if the material zones are set up in a way that would allow that.
There's these:
https://www.daz3d.com/slinky-dress-for-genesis-8-females
Thanks! They have lots of great shoes, but did not find one that works for me.
Ah, yes. Really like those, but looking for straps rather than ribbon-like wraparounds. Thank you, though!
Ooo, these would be perfect if not for the heels. Will definitely kitbash this one if there is nothing else on point. Thanks!
I went through my runtime and other than the sandals you have looked at, I had flats with straps going up to the shin. Some of those were pretty great, but are you able to take the shoe into Hexagon and modify the heel? Or just pose the foot and hide the heel area?
Sorry for the delay, I have been crazy busy today and not on the forums much today.
So went in, and found seven possibles, four for G8F, one each from V4, G8M, and G3F (in case you can convert). I did a quick render, with the G8F's in the front, and the other three in the back, in that order. I am including the links below:
https://www.daz3d.com/barbarian-warrior-outfit-for-genesis-8-female-s
https://www.daz3d.com/dforce-seasons-maiden-outfit-for-genesis-8-female
https://www.daz3d.com/dforce-summer-muse-outfit-for-genesis-8-females
https://www.daz3d.com/dforce-qabbalah-outfit-for-genesis-8-females
https://www.daz3d.com/kimani-clothes-for-v4
https://www.daz3d.com/summer-maxi-dress-for-genesis-3-female-s
https://www.daz3d.com/dforce-toga-outfit-for-genesis-8-males
I hope these may help you, or give you an idea of where to look in your own library.
Mary
Wow, very nice selection and I do have most of them! Thanks.
You're probably already sorted by now, but saw these sandals in today's PC for a day and remembered this thread. Old, but could be worth a try at only $1.99.
Rope Sandals for V5
