Keeping locked dials intact
How can I keep locked dials intact? I have noticed that some dials affect others, locking the affected dials and reverting the ones which affect them changes the locked dials too. Even memorizing selected items does nothing (I thought it would memorize the selected dials settings, but that doesn't seem to be the case for some reason), since it restores the other dial too. (Not sure why it does that, since it should only be memorizing the selected dials unless I am interpreting it wrong)
Let's say there's a morph that gives me dial A which in turn affects this dial B from another morph (or default daz ones) and I want to just keep B intact and reset A back to 0. How can I do so? I would understand if both of them changed the shape of one thing, but that's not the case.
I am trying to preserve a part of the character's shape, if anyone's wondering. The body dial of the character changes several things and I wanted to keep the setting of one of the dials it affects.
Either change the limits of the particular dial to not drop below the preferred value, click the gear icon to access the slider menu, or adjust the dial directly and lock the parent dials.
In some cases, dials work in both directions. Change a value on the sub-dial, the parent dial changes as well.
Just depends on the particular slider type.
I thought there might be a way to freeze them but I'm not sure how. the fact that the lock is ignored is frustrating and there needs to be a button "lock for realzies", otherwise what is the point.
