Fit Control for Genesis 8 (Commercial)
1568101118
  • barbultbarbult Posts: 26,542
    Uthgard said:
    ... I swear I don't spend an inordinate amount of time and mental effort to strip my virtual dolls. Emphasis on "inordinate."We
    We know that! wink They come naked in the first place. If you were fixated on nakedness,you wouldn't clothe them at all. laugh Oh, think how much frustration that would save! We would save a fortune on Daz clothes not purchased... We wouldn't need Fit Control at all.... But we could never post an image in the forum or gallery...
  • Zev0Zev0 Posts: 7,123
    edited May 2020
    Uthgard said:
    I think what Hookflash is talking about is the unfortunate glitch that happens when a morph pushes the mesh beyond the bone it's assigned to, such as, for instance, lowering the pants of a figure and then posing that figure leaning forwards. The waist of the pants, which could be at the thigh bones, will still react to the movement of the waist, making a very weird curve that renders it unusable. Same thing happens when moving a strap to the arm and then posing said arm. I normally get around this by using dforce after using the morphs on the zero pose and then animating the transition (said he, as if he was productive enough to "normally" do anything) but having the rigging automatically fixed would indeed be a very nice feature, like Aeon Soul has done in some outfits with different versions (not that the outfit automatically adjusts to the fitting morphs, just that there are are two pants to load, one normally worn and one halfway down GF8's leg, for example).
    Ah ok. Ye best solution is to adjust clothes when figure is roughly in it's final pose. No way around that regarding the bones.
    Post edited by Zev0 on
  • UthgardUthgard Posts: 881
    Indeed it would be a tragedy, being unable to share our creations because nowhere on the internet is there an audience for naked skin. Thankfully, we have our truckloads of skimpwear to preserve the graceful modesty of the digital form.
  • ATA for the update? every time I foget to delete the eyelashes... CRASH!
  • I mentioned a potential useful function in the Dial Control thread, in that not only would it show the paths for morphs on a character, but also the paths for clothing items?
    Having thought about it,  I added that it could be potentially more of a function of Fit Control.
    You mentioned that because clothing typically had fewer morphs, it would be of limited use.
    What I am thinking of though, is that I often, & I suspect others do too, save kitbash outfits as a wearable preset.
    If the paths for clothing locations could be shown, perhaps via a seperate related script, it would ease finding installation of individual items to facilitate morph adjustments & texture changes.
  • SevrinSevrin Posts: 6,314
    How is the update to address the Fit Control for Genesis 8 Female using the current beta coming along?
    edited June 2020
    The update will be finalized as soon as we get XTransfer G8 to G3 out. We are running behind at the moment unfortunately........We thought a reversed XTransfer was going to be a quick process but we hit quite a few issues because of the slight differences in the UV's. So once XT module 2 is complete Fit Control all versions will get the update. We haven't forgot about it..It it is highlighted in red on our to do list, but XT is way behind release schedule and that urgently needs to go out....
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,983
    Has this crash situation been fixed yet?  Not interested in the workarounds
    DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZStudio4\QtScript4.dll" at 0033:00000000A3CCE1BC, QScriptEngine::signalHandlerException()+18380 byte(s)
    edited July 2020
    When is it crashing? Can you send me your log please.
    Tried to PM but didn't know how to attach this file
    txt
    txt
    log FC Crash.txt
    898K
  • xyer0xyer0 Posts: 6,405
    edited July 2020
    I haven't used Fit Control on Genesis 8 Female in a very long time (last August) because of consistent crashes. I was just checking to see if anything new had come along.
    Post edited by xyer0 on
    This is my first time using it for G8. Crashes every time. Just checking to see if it was something I was doing
  • jardinejardine Posts: 1,219
    do you still need crash logs, zev0?
    i really miss being able to use fit control.  but it's been crashing immediately after applying the morphs for months.
    I need logs yes. I need to see when it crashes and at what stage.
    edited July 2020
    It's frustrating because here I just did a test and doesn't crash. So yes send logs so we can see at what stage it is crashing. Video is in zip
    zip
    zip
    test.zip
    2M
    Thanks @Zev0.  It crashes as soon as you select the item to apply the fit control to and accept
  • the5amkebabthe5amkebab Posts: 103
    Crashes Daz every single time once it says morphs have been added and I click "ok", crash, Daz fatal error message pops up and nothing is added to the log file, it just dies. From what I can tell, users on other forums are reporting the same thing regardless of Daz version so is there anyway it could be a problem with the program clashing with a recent windows or a recent Nvidia driver update as everyone seems to have been getting it within the last few months? Maybe @Zev0 isn't able to reproduce the error if you're working on an older version of windows, older driver or something along those lines?
  • attached is a log file from when it crashed. i sometimes get it to save while pressing the save button as it's working, but otherwise, nope. I really miss being able to use it.
    txt
    txt
    log file.txt
    4K
    hi, z...
    i just PMd you dropbox links to the three crash logs i generated thismorning, and some notes.
    j
    Thx
  • raceresqraceresq Posts: 9
    edited July 2020
    Same problem here. DAZ crashes right after accepting
    G8 only, other versions work well
    txt
    txt
    log.txt
    46K
    Post edited by raceresq on
  • I have the same issues with the G8F version. All the other model versions (G3F, G3M, & G8M) I own work fine. I have the same crash report problem some are reporting because it CTDs so fast that DS doesn't even attempt to add info to the log.
    I Just deleted 4.12, and went back too 4.11....that solved the problem, fit control for G8   WORKS FINE NOW
    How did you get it to work right? I'm on 4.11 and it crashes.
  • DeimoDeimo Posts: 2
    How can I take back the 4.11? :D
  • LeanaLeana Posts: 12,967
    edited July 2020
    If you don't have a backup of the install files you can try opening a support ticket to ask if Daz support team can provide you with a copy.
    Post edited by Leana on
  • Rod Wise DriggoRod Wise Driggo Posts: 2,335
    Hmm, I'm on 4.12.1 und would not like to go back as some other products rely on the latest.
    @Zev0: Any chance a fix for Fit Control on 4.12 is coming?
    Partner has been swamped with day job responsibilities since this corona thing. We are aware of the pending update that needs to go out. It will be released when time has been dedicated into finalizing it. Even XT G8 version has come to a halt for now.
    Well, it worked for 2 days, and it went wrong again
    DAZ 4.11
    txt
    txt
    log.txt
    85K
  • Hmm, I'm on 4.12.1 und would not like to go back as some other products rely on the latest.
    which products would those be?
